Results 1 to 4 of 4
    Newbie hook is a glorious beacon of light
    Sep 2009
    Oregon
    Default Transmission Temp
    I just had my gauges rebuilt and had a oem trans temp gauge installed in the cluster. Everything works OK but the trans temp runs about 125 after about 20 miles of highway and city driving. I'm wondering if the gauge reads low or is this normal? I was expecting 150+ for normal driving. I have a 03 4.8l 2wd with the factory external trans cooler.
    Rod
    2003 Silverado ext cab 4.8l
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by hook View Post
    It takes the trans longer to warm up then the engine. This is normal. Once the engine has been running for an hour or so under normal driving conditions the trans temp will be slightly lower than the engine temp. So if your truck runs at 220 your trans will be around 200. Once the transmission is pulling weight the temp will go up. 250-270 is normal pulling a trailer, etc. 275 is borderline and here's where synthetic oil shines as it can handle this temp for extended periods with no problems.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Sr. Apprentice agerangere5 is a glorious beacon of light
    Oct 2009
    i just checked my temp out today while driving with no load my tranny was only at 115. that was after a good 30-40 min of driving on the interstate.
    2009 silverado crewcab ls - VA
    Sep 2009
    Oregon
    Thanks guys, I just wanted to know it was correct. Looks like it's working correctly and has been running at 150 on extended driving.
    Rod
Similar Threads
  1. transmission temp
    By sexysilverado25 in forum Powertrain
    Last Post: 04-25-2010, 09:35 PM
  2. Transmission Temp. Gauge
    By sc99z71 in forum Audio / Video Electrical
    Last Post: 11-10-2009, 04:17 AM
  3. transmission temp help
    By yukonlover89 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 10-05-2009, 05:53 PM
  4. Transmission Temp
    By bill18163 in forum Powertrain
    Last Post: 05-17-2009, 10:49 AM
  5. Transmission temp gauge help
    By jc8825 in forum Powertrain
    Last Post: 04-12-2009, 10:51 AM
