Results 1 to 3 of 3
    Newbie geodiggr is a glorious beacon of light
    Aug 2009
    Default 1991 GMC Suburban Ignition issues
    Hi all,
    1991 GMC V1500 Suburban, 5.7, 4wd, 700R4, 160k
    I am having starting issues with the vehicle. Initially, it was thought to be a fuel pump...but after it finally not starting after 4 months of sitting I have determined that it is a spark issue.
    Weather finally started getting colder. Truck would not start. Turns over, but does not fire. Put a spark plug tester on the plugs and no spark. Try it later in the day (warmer), no spark at first...little blip, no spark, then spark and it fires and runs for about 10 secs and cuts off. Tried this test on two different plugs/wires and both had the same results.
    Checked the coil today and it seems to test ok...
    Problem is, the problem doesn't occur all the time. Seems that it occurs when engine is hot on restarts, when I cut steering wheel hard or to limits, or when it is cold outside. Cold outside seems to be the most consistent no start...so far.
    Pulling my hair out on this one...any and all help would be greatly appreciated!
    Thanks,
    Rick
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Try this:
    Pop the distributor cap. If you see a lot of red dust, you'll need to replace the cap and rotor. The red dust comes from the metal in the distributor. The rotor gets a small hole in it and the high voltage from the coil arcs to the metal surfaces under the rotor and oxidizes the metal, hence red rust colored dust/dirt.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Sr. Engineer azdrtdog is a glorious beacon of light
    Apr 2009
    phx.
    Cold engines need hot spark for rich mix i think the problem is always there.just more of a pain when cold. definetly check your cap and if the wires are old maybe replace check spark at cap
    99 tahoe 2 dr. 4x4 7.4 4L80-e NP246, SAS, dana 60 hp, sterling 10.5 rear, gibson headers, and alot of tricks of the trade !!!!!!IF YOU'RE NOT CHEATING YOUR NOT TRYING!!!!!!!!
Similar Threads
  1. 1991 Stalling Issues
    By geodiggr in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-08-2010, 03:50 PM
  2. 1991 Suburban Tow rating
    By regi_dog in forum General Chevy Tech Q&A
    Last Post: 12-08-2009, 04:36 PM
  3. 1991 GMC Suburban starting issues...
    By geodiggr in forum Powertrain
    Last Post: 09-03-2009, 11:04 PM
  4. 1991 Suburban
    By Runsfunny in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-04-2009, 10:51 PM
  5. 1991 Suburban
    By Truckernate in forum For Sale & Wanted to Buy
    Last Post: 04-25-2006, 11:50 PM
