    Sr. Apprentice Scott77's Avatar
    Nov 2008
    South Florida
    Default Getting the fuel pump gasket to stay where it belongs?
    Hey all, I'm in the process of changing out the fuel pump on my 97 Tahoe 5.7l 4 door. I can't seem to get the gasket to stay seated, once I tap the lock ring into place part of the gasket is sticking out. Any tips ???
    2008 Silverado LT
    Sr. Engineer
    May 2009
    Manitowoc, WI
    Did you get a new one or are you trying to re-use the old one?
    Hi lub it use some wd40. That will help ralph
    http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
    2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
    6-PIAA 520 series yellow ion spot lights 85 watts each
    PIAA quattro fog lights w/extreme white/yellow ion bulbs
    Anzo projector headlights/LED turn signals
    LED underbodys 7-color/LED interior lighting
    JET stage 2 performance chip/Magnaflow exhaust S/S
    Recon Big Rig Lights/LED tail lights/3rd brake light
    Putco LED bed lights/BEDRUG
    Goodmark 2" rise Cowl hood/K&N fipk intake
    98-04' Blazer overhead console & floor console
    40/60/40 seat modified to 40/console/40
    33" Cooper Discovery A/T
    16" Pro Comp extreme alloy wheels
    Nov 2008
    South Florida
    It's the new one that came with the pump, I'll try some lube as recomended, thanks.
    Dec 2009
    Deep River Ontario
    try using some copper gasket spray adhesive, that gasket wont move around at all after that tacky stuff is on
    06 Z71 Silverado Military Style!!!
    Red Seal Certified Automotive Service Technician
    Sounds like you might be over-tightening the fasteners. Check the torque spec and use a torque wrench to install the fasteners.
  1. Chevy Express Silverado Water Pump O-Ring Gasket 01-09
    Last: 06-11-2010, 01:10 PM
  2. water pump gasket question
    By jman308 in forum General Chevy & GM Tech Questions
    Last: 11-30-2009, 10:07 PM
  3. Twitching/vibrating fuel gauge - Not the fuel pump assembly.
    Last: 09-26-2008, 05:10 PM
  4. Fuel Gauge sender/fuel pump Together-seperate???
    Last: 09-05-2008, 02:55 PM
  5. starts but won't stay running, is it the fuel pump ?
    By ministock8 in forum GM Powertrain
    Last: 07-31-2007, 12:27 AM
