GM Truck Club
Page 2 of 3 FirstFirst 123 Last Post byLast Post by
Results 11 to 20 of 21
Thread: Air bags
  1. #11
    I have an air lift set up on my 2500hd crew cab short box. They came with the truck when i bought it and they are incredibly nice for any added weight from over sized loads that is too much for just stock leaf springs. The only down fall to it is their are 2 seperate air lines, one for each bag that have to be filled with an airchuck at the rear on each side of the license plate. Ideally id like to route them to just inside of the fuel door to clean it up but they are hardly noticeable on the bumper.
  2. #12
    Jr. Engineer lsutoms's Avatar
    Sep 2009
    baton rouge louisiana
    Quote Originally Posted by Awesraws5 View Post
    What do you mean by an air chuck????
  3. #13
    Quote Originally Posted by lsutoms View Post
    Here is a pics of a Air Chuck,
    http://www.google.com/products/catal...557&sa=title#p
    MIKE
    99"SILVERADO
    5.3 l 3.73 l G80
    BLACK BEAR CUSTOM TUNE
    SNUGTOP l COLORMATCH l KATZKIN
  4. #14
    Sep 2009
    Quote Originally Posted by 99'HEARTBEAT View Post
    Air Lift has 2000lb bags and 5000lb,I have the 2000lb bags.I tow a Boat and boat,motor and trailer around 3500lbs.With that I run about 40 to 45lbs in the bags.With the bags my truck now ride's Better and Handles better,Does Not Bottom out,I will not tow without bags every again.
    I would add one more item.I wanted to put on the 5000lb bags.But the shop that put on the bags told me that,I did not need the 5000lb,and that the 2000lb would do the job.The shop was right.2nd he told me that the 5000lb were for 3/4 trucks.
    Are these bags 2000 lbs a piece or a set? I usually don't haul but about 4000 lbs though so If your doing fine with this I should be also
  5. #15
    He means with an external compressor like you would do with your tires. He doesnt have the onboard setup.
    I have installed and used the 5000lb bags from firestone on a F150. I want to get them for my truck as well. they work great. Here is the firestone link.
    http://www.firestoneindustrial.com/riderite/
    David
    2004 Silverado 2500 Crew Cab 4x4, AMSOIL EA air filter, Granatelli MAF sensor, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST) and 4.10 gears, Rhino Liner, EGRUSA fender Flares and widow visors, extended stainless steel brake lines, firestone airbags w/onboard air compressor, Pioneer Avic X940BT navigation, Accel backup camera.
    http://www.gmtruckclub.com/forum/sho...Silverado-2500
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    2013 Toyota Avalon Limited (Wife's Car)
    NRA Life Member
  6. #16
    Went you buy,a set of bags.What you are getting is the bags[both side's]the air lines and Mounting hardware.
    Example,
    http://www.summitracing.com/parts/AI...6/?image=large
  7. #17
    Sep 2009
    I'm guesing that you have the male end o the air chucks feeding straight to your bags? I currently have an onboard air system so I would just run air hose straight from them
  8. #18
    It will be the set, even though they say dont exceed the payload capacity. So my payload is Just over 3k but the bags will support up to 5k. they are rated more for weight in bed and not necessarily trailer weight. so if you have a 10k trailer it will still level just fine
  9. #19
    If you are looking for 2000lb Bags,here is the set you would Buy for your truck .Went I bought my bags I also at the same time had the Compressor & Controls installed at the same time.it would be up to you in you want to add the Compressor & Control's.For me having Compressor & Controls is a Very nice feature,as I can adjust the bags for the road Condition's as I'm driving.
    http://www.summitracing.com/parts/AI...9/?image=large
  10. #20
    Sep 2009
    Quote Originally Posted by dsfloyd View Post
    have you ever hauled 5k in your bed?? if so did it do fine i have had about 3k plus a trailer and my tires started to bubble out they couldnt handle it and my hitch was almost in the ground lol but i know that a pallet of mulch weighs 6k and i know a boy who hauls that all the time with a ram2500 no problems... i dont know what the weight rating is on my bed hauling weight.. im guessing 1700ish...
Similar Threads
  1. 99 silverado air bags
    By dexterguy in forum General Chevy & GM Tech Questions
    Last: 06-21-2010, 10:16 AM
  2. Air bags deployed
    By teamtaz3 in forum General Chevy & GM Tech Questions
    Last: 05-31-2009, 10:00 PM
  3. hydraulics or bags
    By wolfie in forum Lifted & Offroad Suspension
    Last: 05-06-2009, 02:31 AM
  4. Bags? On a tahoe?
    By Sactotahoe in forum Chevy Truck Accessories
    Last: 08-31-2007, 02:15 PM
