    Nov 2009
    Central California
    Angry Heater ac problems
    I've just noticed that my heater and ac dosnt blow as hard as it used to it's still hot and cold but it dosnt blow as hard any clue on what's wrong. Thanks
    99 Chevy silverado
    6.5 inch FTS lift
    16x12 weld cheyennes
    31x12.5 boggers
    electric fan conversion
    flowmaster 10 series exhaust with 5 inch tip dumped
    autopage remote starter
    Nov 2009
    Central California
    Question
    Anyone?...
    99 Chevy silverado
    6.5 inch FTS lift
    31x12.5 boggers
    could be the blower motor. not sure if it speeds up based on voltage or not. ie the higher settings send more current etc.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Nov 2009
    Central California
    Yeah it goes hard then soft without touching the controls any clue if its pricey and difficulty of install
    99 Chevy silverado
    6.5 inch FTS lift
    31x12.5 boggers
    Default Possible Solution
    Hey do you know if your truck has the cabin air filters? They might be dirty ass hell and not being able to pass the ac or heater air. I had no idea they existed on my truck til last summer I wondered why my a/c was blowing out little a/c on high so I thought it was the freeon, I checked the line and it was full so I did some reach and found that I had cabin air filters, I found them and when I pulled them out they were COVERED in 7 yrs worth of dirt and all kinds of stuff, as soon as I put the new ones in...BOOM the air was blowing thru easy...that cured m problem...you should check if yours has them. Im pretty sure it does!!!
    Joser
    2001 Silverado 5.3L
    13% tint all around
    7" Fabtech lift kit w/ leveling kit
    HD front end conversion
    Blacked out Billet Grille w/ Black Bow-Tie
    33x12.5x20 on 20x10 Fuel Hostage
    Smoked out tail lights
    Dual Flow Masters/ Exhaust Cut outs
    K&N CAI
    Custom Tuner
    Corvette Servo
    180 Stat
    10K HIDs
    "Spending money on things we dont need to impress people we dont know"
    If the air goes soft and hard it could be the motor getting worn out, maybe you should open the housing thathas the motor and see if there is anything maybe wound up with it. Course it could be just old and the brushs are almost gone.
    1995 Chevy Silverado
    Fully loaded!!!
    4Wheel Drive
    5.7 Liter
    Blue
    Best Engine In The World!!!!!
    Once i had a nearly dead battery and was only able to get 1 slow crank per attempt, Once to the fifth crank she fired up! (True Story)
    ________________________________________
    Do you have a Tahoe,Yukon or a suburban? Join My Group
    http://www.gmtruckclub.com/forum/group.php?groupid=26
    Nov 2009
    Central California
    Quote Originally Posted by Thundare View Post
    Any clue on where the motor is?
    99 Chevy silverado
    6.5 inch FTS lift
    31x12.5 boggers
  1. Heater Problems
    By Metaluzc in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-01-2010, 06:43 PM
  2. Heater problems
    By 96Z71VORTEC in forum General Chevy & GM Tech Questions
    Last Post: 11-12-2009, 04:55 PM
  3. Heater problems
    By jb9164 in forum General Chevy & GM Tech Questions
    Last Post: 02-21-2009, 10:05 PM
  4. Heater Problems
    By Mrs Leadfoot in forum Audio, Video & Gadget Tech
    Last Post: 04-01-2008, 05:40 PM
  5. Chevy Silverado Heater problems blower problems
    By bidutch in forum GM Powertrain
    Last Post: 12-13-2007, 05:59 PM
