    Default 2003 2500HD Duramax 4wd problem
    I have an 03 Silveraddo Duramax. The t case was toast when I bought it. I had it rebuilt and thought all was fine. When I went to shift in to 4HI while driving there was lots of grinding/noise sounds like it is coming trom the T case. Spoke to a couple of mechanics and they said maybe front diff actuator was bad so bought a new one and installed it. Still the same problem. When sittling still it all engages fine and no noises at all even when going down the road. At low speed it will engage but wth a loud "clunk" at speed only griding. When I have it engaged and going down road can shift from 4HI to 2HI as long as I dont "unload" the front end. Any ideas on what my problem is?
    Troy
    Hello, I always understood that you had to stop, shift to N, and then change 4WD modes.
    Shifting 4WD modeds on the fly may not be a good idea even if you are going slow.
    stephen
    If both the front and rear driveshafts are turning the same speed, which they should be if the actuator kicked in, then there should be no grinding at any speep from 2 hi to 4 hi.Since yours is grinding the front driveshaft is not turning at the same speed as the rear. Some other things besides the actuator being lazy are different axle ratios between front and rear because someone installed a miss-matched diff. Or different tire sizes betreen front and rear. I would double check the front actuator and make sure it's not sticking.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Moderator: should this thread be in the diesel section too?
    Quote Originally Posted by Jimmiee View Post
    I purchased a new front actuator, installed it , and changed the front fluid. When it is in 4WD and going down the road everything is fine. No strange noises or jerking like you would expect if ratios were incorrect. Any other suggestions?
    Last: 05-12-2010, 09:30 AM
  2. Replies: 0
    Last: 06-21-2009, 06:12 AM
  3. Duramax Driveshaft, 2500HD 2003
    By thpnalb in forum GM Powertrain
    Last: 03-21-2009, 01:31 PM
  4. 2007 GMC 2500HD Duramax
    By waroland in forum Photo & Video Gallery
    Last: 03-14-2009, 09:23 PM
  5. 2003 2500hd crew cab brake problem
    By buckley03 in forum Lifted & Offroad Suspension
    Last: 11-06-2008, 05:10 PM
