Thread: 03 Wiper issue
    Question 03 Wiper issue
    Hey all,
    I know this is a common issue with the late 90`s trucks, but my 03 has come down with a similar wiper power issue. Mine had some funny movements on delay, then switch to low constantly without delay and now wont even shut off at all. I can switch to high but I cannot shut them off without pulling the fuse. I thought GM rectified the board problem within the early 2000 models but I`m wondering if that recall should have moved further up the years. Any suggestions other than the board being bad? Maybe the combo switch this time? Any info or suggestion would be very helpful with winter breathing down on my neck.
    The only tie I`ll were is a Bowtie!
    The whole part is cheap and easy to replace, just do that.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Well, tried the replacement of the combo switch and the issue isnt resolved. Any other suggestions ????? Wipers wont shut off, stay in low even thru delay on the switch, and can be switched to high. Only way to shut them down is to remove the fuse from the fuse panel. Suggestions?
    Well, must have come to the wrong site for help. Thanks
    I was waiting for someone to help you also as I was having the same issue with my 03 sierra. The wipers would not shut off and I put a switch into the fuse panel as a temp fix. I did a lot of reading on this site which narrowed it down to the circuit board on the back of the motor. I ordered a used motor on ebay for $30..thats with a warranty even and simply swapped out the circuit board on the back of my wiper motor, leaving the existing motor in place. Took me 20 minutes start to finish. I couldn't find just the circuit board anywhere so I guess I have an extra motor should I need it.
    Quote Originally Posted by toyhauler View Post
    Jason told you how to fix it. :sarcastic:
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Sr. Apprentice jmutto's Avatar
    Dec 2008
    Washington State
    Hey all,
    I had the wiper problem with my 2004; no recall on my rig.
    I got a new board that mounts on top of the wiper moter and it fixed the problem. I got the board from my local dealer, so I paid way to much for it (of course) but it fixed the problem.
    Board swap takes about 30 minutes (tops) if you know what you are doing.
    Simplified steps:
    1. Remove wiper arms.
    2. Remove plastic cowling.
    3. Remove and replace control board.
    4. Reassemble.
    Good luck.
    "Sometimes, a little brain damage helps" - George Carlin
    2004 Chevy Silverado 1500 Extended Cab "Northwest Edition"
    Volant CAI
    Optima red top
    Westin chrome side steps
    Leer 100XL cap
    Line-x bed liner
    Cat back
    Panasonic DVD headunit
    Alpine amp & sub
    Garmin Nuvi 255 GPS
    Viper 900 alarm with remote start
    ScanGauge II
    Sirius Stratus 6 satellite radio
    BetterBuilt fender well box
    Thanks for the info, and yes Jason did tell me how to fix it in a vague sense, I tried the switch and tested from there. Thanks for the info and I now know what the culprit was. I havent purchased the board because oddly enough, I changed out the old orginal battery and the system is acting stupid anymore(go figure). Anyways, I`ll wait until they go bonkers again and then I`ll get them fixed up.
    Thanks
  1. GM Recalls Nearly 1.4 Million Vehicles for Issue with Heated Windshield Wiper ... - g
    By Steve in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last Post: 06-09-2010, 02:50 PM
  2. Wiper Operation
    By ncof300d in forum General Chevy & GM Tech Questions
    Last Post: 01-16-2010, 02:35 PM
  3. Removing wiper arm
    By Cableguy in forum General Chevy & GM Tech Questions
    Last Post: 04-07-2008, 10:32 PM
  4. Wiper Delays?
    By trenchwarfare in forum General Chevy & GM Tech Questions
    Last Post: 03-31-2008, 10:02 AM
  5. Plz help with my wiper..
    By jimmy22 in forum General Chevy & GM Tech Questions
    Last Post: 03-24-2008, 09:04 PM
