    Default Installing Side Steps
    O.K. ordered some side steps or nerf bars or whatever you want to call em and tried removing the body bolts under the truck where the mounting brackets attach to and no luck getting them off! That's with just a regular ratchet wrench. I'm thinking you need an impact wrench to remove them ****ers! Anyone go through something similar?
    2009 Silverado LT Black
    5.3L Flex Fuel and Active Fuel Mgmt.
    Z71
    I did have to use a long ratchet and a piece of tubing slipped over the end for extra leverage, but they came out fine, although they're very long.
    Be sure, when installing your mounting brackets, that they don't touch the bolt pockets when you get it all tightened down or you'll end up with body creak like I experienced. I had to go back and insert a couple of thick washers between the center bracket and the body to get enough room so it didn't touch. And be sure to torque the bolts evenly; my instructions said to 75 lbs/ft.
    After a couple of days, go back and torque ALL THE BOLTS again after everything settles in.
    Merry CHRISTmas!
    The Cheap-*ss Modder & Thread Killer
    The Realist says, "The glass is too big".
    2013 GMC Sierra 1500 SLT Z60 4WD Crew Cab
    Mineral Green Metallic w/ Tan Leather Interior
    5.3 L FLEX w/AFM, 6A, Cheap-*ss Mods
    32 Dump Club Member
    Range V8 AFM Eliminator
    You shouldn't have to use an impact on those bolts, I have never had a problem with mine. But there's always that chance that your truck was built on a friday, and whoever put the cab mounts on at the factory forgot to put NEVER-SEEZ on them.
  1. Painting side steps
    By Chaser1 in forum Chevy Truck Accessories
    Last Post: 04-14-2010, 10:24 PM
  2. Side steps paint process
    By Chaser1 in forum General Chevy & GM Tech Questions
    Last Post: 04-12-2010, 05:12 PM
  3. side steps.
    By bbwalker665 in forum Chevy Truck Accessories
    Last Post: 11-26-2009, 11:37 AM
  4. Side Steps/nerf Bars
    By MRFASTPHIL in forum Chevy Truck Accessories
    Last Post: 11-10-2009, 06:48 AM
  5. Side Steps.
    By ChevyTech in forum Chevy Truck Accessories
    Last Post: 07-25-2007, 09:36 AM
