Results 1 to 2 of 2
    Default 93 suburban tbi fuel problem need help
    93 suburban 350 tbi when i turn the key to the on position the injectors run wide open and fill up the throttle body before kicking off then when truck is started the injectors run wide open causing the truck too flood and run really rich and white smoke comes from the exhaust and smells really strong of fuel then when you put it it gear and give it gas to take off it trys to die out unless you feather the throttle. i have replaced the injectors and the inject body that has the star bit bolts and the tps and the cts also what could be causing this
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Thumbs up TBI flooding
    Sounds like the Coolant Temp Sensor
    Check these search results:
    http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
    High Desert SoCal
    02 Honda Civic LX
  1. 2002 z71 fuel problem
    By patrickemb in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-25-2010, 09:32 PM
  2. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last Post: 12-13-2009, 05:38 PM
  3. Fuel Problem 97 K1500 Suburban
    By Izone_Dave in forum Performance & Fuel
    Last Post: 12-06-2009, 09:58 AM
  4. 97 gmc fuel system problem
    By smokeydabear in forum General Chevy & GM Tech Questions
    Last Post: 05-03-2009, 05:18 PM
  5. Fuel problem
    By hogger38 in forum Performance & Fuel
    Last Post: 02-13-2008, 06:24 AM
