Results 1 to 4 of 4
    Newbie elsmacko is a glorious beacon of light
    Dec 2009
    Default Where does the vacuum hose from the distributor go to on a 1985 Chevy Pickup w/350?
    Hey I was changing a valve cover gasket for a relative; I noticed the vacuum hose from the distributor is broken.
    Where does it go to? I want to fix it
    Anyone have a link to the diagram also?
    Thanks..
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by elsmacko View Post
    Thanks..
    The vacuum hose goes to a delay valve and through a thermostatic switch on the manifold and then to manifold vacuum. You can bypass all that and hook it directly to manifold or ported vacuum. On my old 85 I had it hooked to ported vacuum and it worked great. If you want it stock, or you need it stock for smog check then you will need the diagram. My truck still had the vacuum line sticker on the radiator support. There are several different ones depending on if you have a Federal or California emissions.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Dec 2009
    Quote Originally Posted by Jimmiee View Post
    Alright; what I'm looking for is the quickest easiest way to hook it up to anything, that will allow it to run good. It's probably a fedarl emissions.
    Is there one quick easy place to hook it up, or can I plug it? Right now it is not plugged in, and it seems to not accelerate good if I floor it.
    I'm looking for a quick dirty easy way to get it back on the raod. In the spring I will re-do them all.
    Newbie A5150 is a glorious beacon of light
    Dec 2009
    blackhorse, ohio
    you will have to find a port below the carb butterflys that looks to be missing a line. somewhere on the front of the carb or manifold.
Similar Threads
  1. Chevrolet : C/K Pickup 2500 1985 lifted chevy truck
    By Steve in forum Chevy Trucks For Sale eBay
    Last Post: 07-20-2010, 10:20 PM
  2. 1985 Chevy 4X4 SWB Pickup Truck
    Last Post: 07-11-2010, 10:29 AM
  3. Chevrolet : C/K Pickup 3500 1985--4x4-- Chevy, Military Pick-Up Truck
    Last Post: 05-07-2010, 09:40 AM
  4. '87 Suburban, vacuum hose question
    By 10 Gauge in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-31-2009, 09:06 AM
  5. vacuum hose diagram [Expired Topic]
    By ellis in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-13-2005, 02:45 AM
