Results 1 to 3 of 3
    Newbie A5150 is a glorious beacon of light
    Dec 2009
    blackhorse, ohio
    Default intermittent shift problem
    have a 95 3/4 ton chevy suburban w/140,000miles. can anyone tell me what would cause the tach and speedo to go crazy and the 4l80e tranny not to shift..... sometimes. thanks
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    You probably have a bad ignition switch. Common problem on these trucks. To check it hook up a volt meter to the transmission fuse. Watch the volt meter while cranking the engine. If the voltage drops below 9 volts you have found the problem.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Dec 2009
    blackhorse, ohio
    thanks Jim,
    no fuses labeled transmission. inside or out. am i looking for something labeled differently?
Similar Threads
  1. Intermittent Wiper Problem
    By JCornaglia in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-29-2010, 08:29 PM
  2. '03 Silverado Intermittent Crank Problem
    By jaf in forum General Chevy Tech Q&A
    Last Post: 01-03-2010, 05:51 PM
  3. Intermittent tranny problem
    By madramper in forum Powertrain
    Last Post: 05-24-2009, 09:27 PM
  4. Intermittent Electrical problem - need help.
    By Tac-One in forum Audio / Video Electrical
    Last Post: 05-08-2009, 12:00 AM
  5. Intermittent Start Problem
    By eglmrk in forum General Chevy Tech Q&A
    Last Post: 03-14-2008, 02:00 PM
