So i have a 94 chevy k3500 6.5 4x4 standard tranny. I have replaced the dual mass flywheel with a single flywheel . I got it together drove it ten miles er so .Than i sherd off the bolts that hold the flywheel to the crank . Everything bolted up nicely . I am confused what may cause this .
incorrect grade of bolts, or tensioner to tight
06 Z71 Silverado Military Style!!!
Red Seal Certified Automotive Service Technician
changed thread title to something more descriptive
Christopher
1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
This is the same truck you had earlier clutch issues with right?
The quality and grade of the fasteners is what comes to mind first.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Were the original bolts torque to yield bolts that were reused?
Please explain the method you used to install and tighten the bolts? This will help to find the cause of the failure. I have been in the transmission business for 38 years and I'm here to tell you this is the second time I've ever heard of this happening.
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
i thought that you needed tha dual mass flywheel no matter what.....
The dual mass flywheels were a good idea and they did smooth out vibrations. The problem with them is they don't live. The bearing between the 2 wheels fails as do the springs and small parts. So the solution is a conventional flywheel which lasts much longer although you do have vibration and rattle that most diesel engines have.
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
Well fella i sold the old girl but i installed the flywheel first and i just tighten the flywheel bolts as tight as i could get them . After fruther inspection at a real garage and they said that the bolts i had in were not long enought he said they were barely in the crank after some new grade 8 bolts and longer ones it seems to be running like a champ a little low rpm vibration but only on take off .$1000 later . i probably should have check that out and tourqued em down ?!
Bookmarks
