    Default Sea Foam walk through?
    I searched for and re-read 2COR517's post from last July about adding sea foam through the booster vacuum hose. I've been considering this for a while, but want a little more info on how to go about it.
    It just as easy as pouring it in the tube? Do I need a buddy to keep the truck running? Do you throttle it to get it good 'n clean?
    Thanks for your input.
    1999 Chevy K2500 Suburban 350
    Master Mechanic zubbiez's Avatar
    Feb 2009
    Eagle Mountain Utah
    go to you tube and search seafoam chevy truck there are step by step videos there that will walk you thru the whole process.
    2000 Silverado Z71 Whipple Supercharger, JBA Headers,3" cat back Flowmaster Exhaust, Volant cai, Pioneer Preimer deck,Orion subwoofer,03 signal light mirrors,03 taililghts
    Here is a how to Video and Writeup on Sea foam,
    http://www.seafoamsales.com/motor-treatment/index.html
    Master Mechanic bigdaddy77084's Avatar
    Jan 2010
    Houston, Texas, United States
    My dad used transmission fluild 1/2 quart down the carb once a year. I would be worried about doing it to a newer motor with all the crap on them. The video did say how long to run Seafoam in your oil??
    I have always been told for the seafoam in the oil is just a few hundred miles then change it
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Thanks for the info gang.
    all you have to do is pour about a third of the bottle in.make sure you do it slowly because if you pur it in to fast the truck will bog out and shut off. It takes a little while to get the third of the bottle in. Let the truck sit for about five to ten minutes with the engine off then crank her over and watch it pour out the white smoke ha its a gassers ways to smoke someone out.
    When you use this in the oil and it cleans the bigger slug out can it clog anything up?
    Thanks
    murdog94's Avatar
    It is supposed to break the sludge down so it will filter thru, and or stay in the bottom of the pan.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Sr. Mechanic SmokeU's Avatar
    Aug 2009
    Fitchburg, WI
    Quote Originally Posted by bigdaddy77084 View Post
    Its 300 miles
    2004 Chevy Silverado w/ 5.3L V8 / Z71 / Shorty
    Would rather be going too fast then too slow:out:
  1. Sea Foam in Vaccuum Lines
    By Farmerdave in forum Maintenance & Upkeep
    Last: 11-01-2013, 02:05 PM
  2. Sea Foam use
    By dsquared in forum GM Powertrain
    Last: 05-26-2010, 07:59 AM
  3. Sea Foam
    By Chad01 in forum Performance & Fuel
    Last: 02-17-2010, 12:09 PM
  4. AMSOIL Power Foam (APF)
    By 1st Synthetics in forum 1st Synthetics
    Last: 07-21-2009, 05:40 PM
  5. They Walk Among US
    By Cableguy in forum Games Forum
    Last: 04-17-2009, 05:29 PM
