Sorry about posting 2 threads today but I'm quite concerned about this.
I have a 2005 silverado 2500 duramax & yesterday when I was driving around 60 mph I went to pass a semi & when I hit the gas the truck completely lost power. It was totally powerless & I couldn't pass him. I tried twice.
I programmed one of those powertech jobbies but a couple weeks ago when I went to start my truck it was dead. No lights were left on & I still don't know why that happened, (maybe the extreme cold on the battery?) Anyways, could that have reset the power upgrade on the truck like it resets your electrical?
Why did I not have any power? I'm stressed out.
Thanks!!
Erica
I love my new 2005 Silverado 2500HD LT and...............
My next vehicle will be a 2006 Duramax Hummer H1 wagon
Have you changed your fuel filter lately? Maybe its clogged?
Dead batteries won't erase a tune.
Might be time to change it if its been a few months, especially if you fill up at smaller stations that don't have fuel filters on their pumps like truck stops do...
Ok thanks.
I don't know if that's the problem but I'll get it changed.
It can't be stressed enough that the fuel delivery system on a diesel needs regular maintenance. Filter schedules can't be ignored. Stay away from cheapie diesel, buy the good stuff from a major distributor. Start using a diesel additive if you aren't already.
Based on the age I'd suspect clogged or faulty injectors. My buddy has an 05 and he has been replacing them one at a time. (Rather expensive about $500+ each) We'll be cruising along and boom, the power just disappears. Sometimes he can limp it home other times out comes the AAA card. Both times a bad injector. If you are going to replace them one at a time you have to know which one is bad. Your mechanic can test them. Otherwise you have to pony up the dollars to replace them all.
Head on over to diesel power mag for a couple of good articles on diesel fuel injection: dieselpower1 dieselpower2
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
This time of year with the cold weather water in your Diesel fuel is popular, water will make your truck act a lot like this. Changing the filter should clear up most of the water in your tank and as posted an additive will also help.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
So how often should the filter be changed? It still says it's at 46% on my electronic indicator.
every 12K to 15K miles the filter should be changed.
Also you should try Amsol's diesel concentrate with cold flow improver.AMSOIL Diesel Concentrate Plus Cold Flow Improver is formulated with excellent detergency properties to help keep injectors, rings, piston crowns and the fuel pump lubricated, plus lowers the cold flow filter plugging point (CFPP) by as much as 34 F (19 C) in ultra-low sulfur diesel.
2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
Preferred Customers Save up to 30% Click here!!!
Executive Direct Jobber ZO# 1695636
Scott Douglass 248-721-1002
Order online: www.1st-synthetics.com
Sorry, one more thing.......
I was told not to use fuel additives in the Duramax.
Bookmarks
