Results 1 to 9 of 9
    Default No Dome lights 1999 Suburban
    Having an issue with the overhead lights, will not work with door open or with switches. Although the lower lights come on when the door opens. Any ideas on how to begin diagnosing this problem. This is a 1999 Suburban LT 5.7 Anyone else with this problem out there?
    Thanks
    mamaza
    Dec 2009
    calgary alberta
    need more info.i assume you tried changing the bulb?
    I have checked the bulbs and replaced the fuse, you can use the switch and the lower and door lights come on.
    i had a similar problem with my 04 silverado it started when my check engine light came on for a p0446 (evap leak) after i fixed the problem and cleared my check engine light instantly my dome light worked with the door open. go figure
    Problem Solved!!!!! On the drivers side there is a panel that houses most connectors to the vehicle. Its behind the plastic piece where your left foot might sit, or the panel that the hood release is behind. The connector was completely corroded, looked like moisture had somehow gotten into it. I used 3M multiwire connects moisture resistance, purchased from Wal-Mart for about 10.00. AllDome lights and reading lights function normally. Be careful of the hood release when removing the plastic piece, it looks like it it becoming brittle. Let me know if you have any questions.
    Thanks
    Mark
    Good find. Now where did the moisture come from...?
    1999 Chevy K2500 Suburban 350
    murdog94's Avatar
    If it was my truck id know.. minnesota wieght reduction....
    Back to the question do you have a bad door seal?? or at least a leaky one??
    Mike
    Currently
    2011 F-150 Crew 4X4
    Good question since that was the only connector of 4 in that tight area that was corroded.
    murdog94's Avatar
    Quote Originally Posted by mamaza View Post
    Guess its time to do some a loookin....... Good luck it also might have just been humidity... Ive seen that one cars when i was doing upholstery in Ga.... A lot of the time for the power seats etc...
  1. 1991 Suburban Dome / Cargo lights will not go off
    By carkti in forum General Chevy & GM Tech Questions
    Last Post: 09-09-2009, 09:49 AM
  2. Dome lights???...03' Suburban
    By SoundZman in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-21-2009, 09:39 PM
  3. 1990 suburban - How do I turn off dome lights w/doors open?
    By omnisi in forum General Chevy & GM Tech Questions
    Last Post: 03-22-2009, 06:38 PM
  4. 1999 2500 suburban no brake lights
    By jason.bierschwale in forum Audio, Video & Gadget Tech
    Last Post: 11-17-2008, 12:44 PM
  5. 1999 Suburban Running Lights
    By hac20853 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-13-2008, 11:54 PM
