    Default resetting oil change light & changing distance when it comes on
    So ive had my 2006 denali for a little over 3 months now and its time for its first oil change. My oil change % is about 45% right now and there is roughly 3000 miles since its last change. When i change my oil this week how do I reset that counter? also how can I change the distance so the light comes on after roughly 3000 miles?
    Not sure how often gm recomends changing the oil in the 6.0l but I dont drive much anymore and if I go 5k between changes were looking at over 6 months of oil.
    -Gary
    hi it tells you in the owners manual how to reset it. i dont no if you can change the milage on tne other part. ralph
    http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
    2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
    6-PIAA 520 series yellow ion spot lights 85 watts each
    PIAA quattro fog lights w/extreme white/yellow ion bulbs
    Anzo projector headlights/LED turn signals
    LED underbodys 7-color/LED interior lighting
    JET stage 2 performance chip/Magnaflow exhaust S/S
    Recon Big Rig Lights/LED tail lights/3rd brake light
    Putco LED bed lights/BEDRUG
    Goodmark 2" rise Cowl hood/K&N fipk intake
    98-04' Blazer overhead console & floor console
    40/60/40 seat modified to 40/console/40
    33" Cooper Discovery A/T
    16" Pro Comp extreme alloy wheels
    Owner's manual for reset instructions. GM uses a proprietary algorthim for determining oil life - you won't be able to change it.
    Master Mechanic shadowt_t's Avatar
    Oct 2009
    Baghdad. Iraq
    first turn the on acc and open ur hood ...open the posative cable on battery wait 10 min after that put the posative cable again turn ur car the yellow light for servies will go
    ashes to ashes dust to dust:slap:
    chevy tahoe 08 LT with sunroof
    cd changer leather seat ,20"wheels
    chrome full set 5.3 V8 back sensores
    4x2 fog lamps and full tint
    Cool resetting oil change light& changing distance
    On my 05 Silverado to reset the oil change mileage you turn on the ignition and quickly depress the gas pedal five times. I dont think you can change the mileage frequency to change. If you use a good oil filter and oil than you should be ok with the factory oil light change frequency.
    you cant change the interval as it changes with driving. to reset the light turn the key on but dont start then depress pedal 3 or 5 times (i think I did it with 3 last time) then turn off the key and restart truck.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    you reset it the way DSFloyd said. I work in a shop that does maints on car and trucks all the time.
    Nov 2008
    Endicott, NY
    Quote Originally Posted by Hid_positive View Post
    -Gary
    You don't need to change the oil every 3K miles on modern engines. The GM OLM tells you when to change the oil, the only exceptions to that are if the OLM doesn't turn on the change oil indiator before you go over the max miles defined in the owner's manual for your vehicle or once per year if you don't drive far enough to drop the to get the OLM low enough to turn on the indicator. Before I retired I was changing the oil in my Tahoe twice per year (12K miles per year) based on the OLM, since I retired I drive about 6K miles per year and change it once per year. My Malibu (6 to 8K miles per year) gets changed once every 10 months and my Corvette (4K per year gets changed once per year.
    Bill
  1. Change Oil Light
    By My99Silverado in forum General Chevy & GM Tech Questions
    Last Post: 07-26-2010, 10:00 PM
  2. Change oil light is on
    By mvince20 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-24-2010, 12:54 PM
  3. Change Oil Light
    By mowerboy1000 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-10-2007, 04:20 PM
  4. resetting change oil alert
    By bigbrett in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 06-27-2007, 11:39 AM
  5. oil change light
    By 06z-71 in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 02-19-2007, 12:46 PM
