    Default wont go in 4 wheel drive
    hello a friend has a 1994 s10 blazer with push button 4x4 it will go into 4x4 high and low but the front wheels dont pull could it the actuator valve on the front axle or the motor on the transfer case? how can we determine which one is bad? thanks
    Sounds like the actuator went bad. My experience was a little different though. When my actuator when out, the second I popped it into 4hi/lo, the 4wd fuse blew. So, 4hi was the same as 2hi, and 4lo was only 2lo. The actuator (for me) cost about $70, and 10 minutes worth of time to replace. Very simple.
    Of course, I have a manually shifted transfer case, so it could be something in all the switches. Doesn't sound like it, though.
    EDIT: If he puts it into 4lo, does he still have the gear reduction, and only 2lo, or does nothing happen, and it's like normal 2hi, even though he tried putting it in 4lo?
    Current truck: 1996 Ford 250, 7.3 Powerstroke diesel. Dana 60 SAS, stage 1 160cc injectors, T500 High Pressure Oil Pump, TS 6-position chip, full 4" exhaust, intake, 285 Falken Rocky Mountain AT's, boost/EGT/trans temp pillar gauges, etc...
    any ideas let me know
    Did you see my EDIT in the post above? Any of those?
    From your first post it sounds like you're saying he has 4hi and 4lo, but the problem is it's really only 2hi and 2lo. Am I on the right track?
    He has a vacuum leak.
    ~~Aztec Car Club~~
    it goes into low range but the front wheels dont pull
    That really sounds like a bad actuator. That's exactly what my truck did when it went bad. You could put it in 4hi, but since the actuator wouldn't engage, it was basically like 2hi, and 4lo was only 2lo.
    Check the 4wd fuse to. My would blow the instant i put it in 4 because of the bad actuator/
  1. converting 2 whel drive to 4 wheel drive
    By jdaugherty3 in forum GM Powertrain
    Last: 11-24-2013, 07:15 AM
  2. 4 Wheel Drive
    By crane557 in forum GM Powertrain
    Last: 06-22-2009, 11:14 AM
  3. 4 wheel drive
    By andrew bookout in forum Chevy C/K Truck Forum
    Last: 03-19-2009, 10:09 PM
  4. new 4 wheel drive
    By chevymarine in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 04-20-2005, 10:26 AM
  5. FOUR WHEEL DRIVE!
    By ChevyFan in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 03-06-2005, 04:14 PM
