Thread: Drive Belt
    Default Drive Belt
    So I took the truck to the dealership because I heard a squeaking noise from the engine (especially during a cold start). The truck is just over a year old and only has 12,600 miles on it. The dealership replaced the drive belt (under warranty) stating it was worn and fraying. My question is why would a drive belt with only 12,600 miles on it be worn and fraying??
    Bobby - North Carolina
    2008 4x4 5.3L V8
    6" Suspension Lift and 1.5" Body Lift
    20x9 Ballistic Jesters w/35" Toyo Open Country MT's & 1.5" rear wheel spacers
    4:56 Yukon Gears
    Hypertech Speedometer Calibrator
    Baja style bed mount spare tire carrier
    Flowmaster 40 series dual exhaust
    Recon Smoked LED tails/3rd brake lights/black projectors w/switchback LED's in the corners
    N-Fab Nerf Steps
    K&N CAI
    No Fear Pedals
    Tint, Line-X bedliner, Window visors, Rear wheel well liners
    Painted front grill, bow ties and door badges, de-"lettered" tailgate
    Powder coated front and rear bumpers
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Default Serpentine belt noise
    Sure, your mileage may vary. Typically you want to start checking the belts at 20k miles, but high temps, chemical exposure, and mechanical damage can cause premature belt failure. Dayco recommends replacing serpentine belts that have more than 4 cracks per inch.
    Here is a great video on serpentine belts:
    [ame="http://www.youtube.com/watch?v=vJtiK_pIYsk"]YouTube- DAYCO's "W" PROFILE BELT[/ame]
    High Desert SoCal
    02 Honda Civic LX
    Thanks for the info!
    2008 4x4 5.3L V8
    4:56 Yukon Gears
    N-Fab Nerf Steps
    K&N CAI
    No Fear Pedals
    they usually will get a dry rib or dry spot in a rib and start making noise
    a good quick fix. take some dialectric grease, about the side you'd put on your toothbrush, and apply to the outside and inside of the belt. as it turns it will spread itself out. If you put to much it will make more noise
    i dought it was fraying, they probably said that for warranty to cover it. but If so, you most likely have a mis-aligned pully
    GM TECH
    05 silverado shortbed
    Thanks Unpluged, aftyer look at all the skit's I'm still going to do it
  1. converting 2 whel drive to 4 wheel drive
    By jdaugherty3 in forum GM Powertrain
    Last Post: 11-24-2013, 07:15 AM
  2. seat belt
    By seaotter in forum General Chevy & GM Tech Questions
    Last Post: 06-11-2010, 04:22 PM
  3. A/C Belt jumping around
    By Crazeetxn in forum General Chevy & GM Tech Questions
    Last Post: 05-12-2010, 08:07 AM
  4. Seat belt
    By Bamf in forum General Chevy & GM Tech Questions
    Last Post: 04-21-2010, 10:37 PM
  5. accessory belt comes off
    By 94VERTiGO in forum GM Powertrain
    Last Post: 07-17-2007, 06:46 PM
