Results 1 to 10 of 11
Thread: Recovery Straps
    Default Recovery Straps
    Is a 2 inch 20,000 lbs enough?
    or is a 3" the better way to go.
    I never owned or used one.
    My vehicle will be a 1500 savana.
    depends on what your tugging with and against 3" straps are insanely strong but a b!tch to store and i've only broken one 2" strap and that was really hitting a f-250 bellied out in deep mud with 38's (and not a ckecker strap good doubled and stiched 2" the cheap ones are not what they claim)
    99 tahoe 2 dr. 4x4 7.4 4L80-e NP246, SAS, dana 60 hp, sterling 10.5 rear, gibson headers, and alot of tricks of the trade !!!!!!IF YOU'RE NOT CHEATING YOUR NOT TRYING!!!!!!!!
    Well like I said I have a Savana and would imagine if I get stuck the basic 1/2 to 1 ton pickup or 4X4, van or vehicle would be towing me out or I them.
    They have both 2 and 3 " 30 footers at 4Wheelparts.com for less than $30 or so.
    So a 2" er is plenty huh? It would be like $8 cheaper than a 3".
    Also is 20 feet enough or would you recommend 30?
    Quote Originally Posted by azdrtdog View Post
    I'm always a fan of bigger is better with strap width, I've only broken 2 2" in over 30 years of wheeling and they both had wear spot where they broke. If you can afford the extra go with the bigger one, it can also be used as a tree saver because of the width.Length is a whole different issue that is determined by the terraign your stuck in usually.
    Make sure to get loops and anything else you need to attach the strap to the truck.
    A clevis pin through the hitch works great.
    Jr. Mechanic GMClone's Avatar
    Jan 2010
    Des Moines, IA
    I've been meaning to ask about these myself. My understanding is the difference between recovery straps and tow straps is that recovery straps stretch, which is why they are to be used to pull a stuck vehicle, and tow straps do not stretch which is why they are meant to pull a vehicle that is not "stuck" but just needs a tow. Do recovery straps only refer to pulling out of mud, or would they be used to pull someone out of snow, or a ditch? I'm looking to build up an emergency kit for my truck, and wonder what kind of strap I should have in case I ever need to pull someone out of snow or a ditch. I don't plan to do a lot of mudding, at least not in my truck's current stock state. Also, I've heard that straps with looped ends are recommended over hooks, does everyone agree? I see tbplus recommends a clevis hitch, which would make sense for a looped end.
    Sorry for the long-winded question, just want to get the right strap to be prepared to help people out. If anyone knows of any other good resources for all of this info, I'd appreciate a nudge in the right direction.
    Truck: 2005 GMC Sierra SLT
    Toy: 2006 Honda 599
    A recovery strap is just that,something has gone wrong and now the recovery begins be it ditch,mud, cliff. A tow strap is the same width at times but not as thick or beefy and I associate them with hooks not loops loops make a strap very strong ot the attachment points when used with pintles or shackles. A snatch strap when used correctly is desinged to stretch out like a bungee and let the wieght of the other vehicle move the load instead of traction in sloppy messes where there is none but are weaker an prone to moisture and uv rays
    http://www.offroaders.com/tech/Tow_Straps.htm
    http://www.offroaders.com/info/tech-...ing/snatch.htm
    They say not to attach the recovery strap to a pin or to loop it through the hitch and to use a D ring instead.
    If you use a pin and the strap angles against the hitch that could cut it.
    And recovery straps can of course be used to pull someone out of sand or snow.
    Quote Originally Posted by GMClone View Post
    I'm going to get a D ring and a locking pin for it and leave it in the hitch.
    The 3" is only $8 more so cost isn't an issue.
    What do you mean by "tree saver".
    A tree saver is wider and can be wrapped around a tree to use the tree as a base to pull from if you have a winch, come along, or Hi-Lift jack.
    I would recommend a Hi-Lift jack at the very least to compliment your strap due to their versatility.
    The "D" ring will work perfect for a connecting point, most of them are smooth and wont put abraisions on the strap making it last a long time.
    Some straps come with leather covers over the loop, I personally prefer these althought they run up the cost of the strap. An old T-shirt wrapped around the loop can do the same thing for cheaper.
  1. AMSOIL Diesel Recovery Emergency Fuel Treatment
    By 1st Synthetics in forum 1st Synthetics
    Last Post: 01-10-2010, 07:59 AM
  2. Replies: 0
    Last Post: 12-07-2009, 03:21 AM
  3. ‚??Turn rate‚?? indicates economic recovery: JD Power - CanadianDriver
    By Steve in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last Post: 11-18-2009, 12:00 AM
  4. Coolant Recovery Tank Issue
    By mavrickwax in forum Chevy Truck Accessories
    Last Post: 03-21-2008, 02:16 PM
