Thread: Timing
    Default Timing
    Timing seems to be off on the 350 TBI in my '94 Silverado.
    What should the initial setting be (0 degrees), with the Computer wire disconnected?
    Pavement sucks... :grrrrrr:
    1994 K1500 4x4 Ext. Cab
    PCM chip and Xenon 8000k bulbs
    350cu.in bored over .050"
    balanced Crank, 10:1 compression
    Flat top pistons,cam,ported heads
    Option Racing Cold Air Intake
    Holley Throttle Body Spacer
    Accell Igition, 45kv coil
    FloTech Headers, no CATs, dual exhuast
    Goodyear Silent Armor A/T 305/70-16
    Pioneer SupertunerIII CD USB Bluetooth
    Kicker ZX200.2 ZX Amp
    Kicker Audio COMP 10" Subwoofer
    Feb 2010
    Avondale, AZ
    There should be a placard under the hood somewhere...
    Feb 2010
    Avondale, AZ
    Start engine and bring to normal operating temp. Unplug the base timing connector located in the distributor wiring harness tan wire with a black stripe use a timing light and set timing to 0 degrees at idle. The timing marks are on the crankshaft pulley and a tab on the timing cover with numerical indications... I think this is what you are looking for...
    Yup... that's it. Set the timing correctly.
    Big difference.
  1. Timing
    Last: 11-09-2009, 10:43 PM
  2. 350 Timing
    By 1991 K2500 in forum GM Powertrain
    Last: 08-11-2009, 08:49 AM
  3. 350 Timing help?
    By SouthernThunder in forum GM Powertrain
    Last: 03-05-2009, 08:06 AM
  4. Help with timing
    By Len in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-26-2008, 11:53 AM
