    Default HELP!!! Ignition Problem?? 99 Surburban 5.7
    I have a 99 GMC Suburban w/ a 5.7L engine that I have been having issues with trying to start. When I first try to start it, it cranks, but doesnt start. If I stop cranking it for a few seconds and turn it over again, it starts after a few cranks. Once it's started, a burnt smell comes into the passenger area from the vents (obviously from under the hood).
    Now, I went to start it the other day, and it wouldn't turn over at all. In fact, now it cranks for a second, totally stops (like there is no current) and then cranks again, all without letting off of the key. Unfortunately, I haven'e been able to get it started yet.
    Can anyone please give an idea what this sounds might be the problem?
    Distributor?
    Ignition?
    Starter?
    I did get a code a few months back of a multiple cylinder misfire if that helps...
    Thanks!!!!!!!!!
    I would stop strying to start it, you could have an exposed wire from the ignition within the steering column and that could be the burning smell, until you can figure it out i would not start it
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Thanks...Is that common? Where would be the best place to start looking for that wire?
    I know there are some other threads about this but if you remove the panel that sits by your knees under the steering column seems to be the place most talked about
    Thanks...I will look for those other posts!
    hi sounds like a bad ground or loose wire at the starter.check the ground cable at the battery.
    http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
    2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
    6-PIAA 520 series yellow ion spot lights 85 watts each
    PIAA quattro fog lights w/extreme white/yellow ion bulbs
    Anzo projector headlights/LED turn signals
    LED underbodys 7-color/LED interior lighting
    JET stage 2 performance chip/Magnaflow exhaust S/S
    Recon Big Rig Lights/LED tail lights/3rd brake light
    Putco LED bed lights/BEDRUG
    Goodmark 2" rise Cowl hood/K&N fipk intake
    98-04' Blazer overhead console & floor console
    40/60/40 seat modified to 40/console/40
    33" Cooper Discovery A/T
    16" Pro Comp extreme alloy wheels
  1. Suburban Ignition Switch/Instrument Cluster Problem?
    By JAL1959 in forum GM Electrical Tech
    Last: 10-27-2012, 12:04 PM
  2. Possible electrical or ignition problem. 2003 Yukon XL ~160K mi.
    By yukonstein in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-20-2010, 04:24 PM
  3. Ignition problem/Can't turn off truck with key!?
    By bradyjames in forum General Chevy & GM Tech Questions
    Last: 07-07-2010, 10:30 AM
  4. 92 suburban won't start- ignition problem?
    By vintage_car in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-18-2010, 08:09 AM
  5. Surburban MPG
    By sysmex in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-07-2008, 09:59 AM
