Results 1 to 4 of 4
    Newbie slkric8 is a glorious beacon of light
    Feb 2010
    Default heater troubles
    intermittent problem - 2004 2500hd Silverado gas, heater blows cold air. Shift manual temp controls up and down a couple of times and warm air blows. What is the issue here?
    Jr. Apprentice Uncle Ed is a glorious beacon of light
    Feb 2010
    Deroit, MI
    Probably the encoder motor on the hot/cold blend door is binding up. They aren't cheap.
    2002 Tahoe LS 4x4 • 5.3 Flex • Corvette Servo • AVS In-channels • JVC KD-PDR80 • BB Engine Tune • Front Mounted Receiver
    1984 3500 3+3 Crew Cab • 350 w/Edelbrock 600• 700R4 w/Corvette Servo & manual TCC • AVS Surface Mount • JVC w/Sub
    Sr. Apprentice karz4life87 is a glorious beacon of light
    Nov 2009
    Denver, CO
    It is the Temp Door Actuater, it is prolly shorted out, and yes they are not cheap by any means i had mine short out on my 04 1500 and still have yet to get it taken care of. I have been quoted anywhere from $800-$1000 from various dealerships and local shops.
    If anyone could help me find out where exactly the actuater is on the driver side it would be great help.
    Jr. Engineer Loggerhead Mike is a glorious beacon of light
    Aug 2009
    Franklin, NC
    disconnect your battery to reset the hvac modules. sometimes the actuators will "loose" the door positions. if that doesnt help you most likely need a new blend door actuator.
    price will depend on where the actuator is at and weather you have to pull the dash to get to it or not
    GM TECH
    05 silverado shortbed
Similar Threads
  1. abs troubles
    By wadestevens in forum General Chevy Tech Q&A
    Last Post: 03-10-2010, 09:07 AM
  2. 04 1500 4x4 troubles..
    By mrpackrat in forum Powertrain
    Last Post: 04-14-2009, 12:09 AM
  3. Timing troubles with my 83
    By SmoothieII in forum General Chevy Tech Q&A
    Last Post: 01-30-2009, 12:03 PM
  4. Light troubles
    Last Post: 01-02-2009, 01:58 AM
  5. 91 Suburban Troubles
    By TechnoGecko in forum Powertrain
    Last Post: 02-25-2008, 10:38 PM
