Results 1 to 2 of 2
    Default Coolant Temp Sensor vs. Temperature Switch
    I was just looking at some parts on AutoZone and saw that there is a Coolant Temp. Sensor and a Temperatrue Switch. They look similar with slight differences and different part numbers. I know what the Coolant Temperature Sensor does but what does the Temperature Switch do?
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    The Coolant Temp Sensor feeds temp readings to the PCM. The temp sensor either lights an idiot light or provides signal to the dash mounted temperature gage.
    See Wells ignition article on the CTS: Wells
    The CTS is the one located near the t-stat housing and the TS is in the block on the drivers side towards the front of the engine.
    High Desert SoCal
    02 Honda Civic LX
  1. Coolant Temperature Sensor
    By Skyking75 in forum General Chevy & GM Tech Questions
    Last Post: 01-21-2013, 09:03 AM
  2. coolant temp sensor
    By engineerbrian in forum General Chevy & GM Tech Questions
    Last Post: 07-15-2010, 04:06 PM
  3. Coolant Temp Sensor
    By Googenheimer in forum General Chevy & GM Tech Questions
    Last Post: 02-22-2010, 11:50 AM
  4. Changing the Coolant Temp Sensor
    By Crawdaddy in forum GM Powertrain
    Last Post: 11-08-2008, 06:32 PM
  5. '82 diesel, coolant temp sensor, Where?
    By kbarrett in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-16-2007, 09:10 PM
