GM Truck Club
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 104
  1. #11
    Quote Originally Posted by blacknight97 View Post
    two questions.. i had my h.i.d's installed by an accesories place. i had 8000's put in. but i feel like they dont project as far as i want. i think they arent aligned. or maybe that cap u were talking about is blocking it. how do i allign the bulbs to make them straight? or is it that bulb cap you were talking about?
    the best way to check how your lights are shining is to find a tall flat wall in a driveway/parking lot that you can pull up to on a level surface (keep about 10-20 feet away). inspect the beam pattern as it shines on the wall. if it looks irregular or brighter in some areas than others, or distorted, then the bulb may be out of alignment. to check the bulb, inspect it as it is sitting in the socket. does it look crooked? does part of the bulb or socket look loose or not seated properly? you don't have H4 bulbs so the cap shouldn't be a problem. also remember with 8000K your headlights will only be about 2/3 as bright as a vehicle running OEM 4300K lights...
    ROTARYENGINEPETE
    '07 GMC SIERRA SLT | Z71 | 4X4 | 5.3L FF
    LIFT:
    ROUGH COUNTRY 3" PREMIUM SUSPENSION LIFT + ADD-A-LEAF
    18" ATX THUG WHEELS
    33" NITTO TRAIL GRAPPLER TIRES
    EBC SPORT ROTORS
    EBC YELLOW STUFF BRAKE PADS
    LIGHTING:
    HELLA/VVME 4300K HID LOW BEAMS
    HELLA BLACK MAGIC OFFROAD LIGHTS
    ANZO USA PROJECTORS HEADLIGHTS
    ANZO USA LED TAIL LIGHTS
    ENGINE:
    K&N 63 SERIES INTAKE
    MAGNAFLOW CATBACK D.O.S.I.F.T. EXHAUST
    BULLYDOG TRIPLE DOG GT TUNER
    PULSTAR IGNITORS
    OPTIMA RED TOP
    DRIVETRAIN:
    YUKON 4.56 GEARS
    MAG-HYTEC DIFF COVER
    CORVETTE SERVO
    TRANSGO SHIFT KIT
    Z-PACK 3-4 CLUTCH
    REBUILT WARN XFER CASE
    BODY:
    RUNCOOL HOOD LOUVERS
    FULL WEATHERTECH VISORS/BUGSHIELDS
    DUPONT BEDLINER
    DEEZEE BLACK DIAMOND PLATE BED CAPS
    BULLDOG LOCKING SPORT FUEL DOOR
    DOOR MOLDINGS REMOVED
    CUSTOM WIRE MESH GRILL
    BUSHWACKER BOSS FENDER FLARES
    CB THRU GLASS RADIO ANTENNA
    5.5sec 0-60mph on pavement (5.2sec running E85), and a little less in 3 feet of muddy water
  2. #12
    Quote Originally Posted by GaryG View Post
    Does anybody make hid kits for a '98 1500?
    I had hids on my mustang an I miss the brightness
    the kits are pretty much universal, all you need to do is order it with the same style headlamp bulbs that you have in your truck right now.
    ROTARYENGINEPETE
    LIFT:
    18" ATX THUG WHEELS
    EBC SPORT ROTORS
    LIGHTING:
    ENGINE:
    PULSTAR IGNITORS
    OPTIMA RED TOP
    DRIVETRAIN:
    YUKON 4.56 GEARS
    CORVETTE SERVO
    TRANSGO SHIFT KIT
    Z-PACK 3-4 CLUTCH
    BODY:
    DUPONT BEDLINER
  3. #13
    Quote Originally Posted by rotaryenginepete View Post
    Do I have the 9006 bulbs? I don't want to order them, then find out I have the wrong ones
    1998 silverado 1500 4x4 - 5.7L vortec
    Bed rails, step bars, bedliner, 18% tint, flowmaster 44 muffler, 16x8 M/T Classic II wheels, 265/75-16 goodyear wrangler duratracs
  4. #14
    yeah you should be running 9006 bulbs, thats the stock one for your headlight.
    ROTARYENGINEPETE
    LIFT:
    18" ATX THUG WHEELS
    EBC SPORT ROTORS
    LIGHTING:
    ENGINE:
    PULSTAR IGNITORS
    OPTIMA RED TOP
    DRIVETRAIN:
    YUKON 4.56 GEARS
    CORVETTE SERVO
    TRANSGO SHIFT KIT
    Z-PACK 3-4 CLUTCH
    BODY:
    DUPONT BEDLINER
  5. #15
    Excellent post, I think it would be a good how-to post if you wanted to throw it up there.
    '01 Chevrolet S10
    -custom air intake
    -painted dash
    -footwell lights
    -Strange Performance stickers
    -exhaust coming soon
    -Xplod Head Unit with iPod connectivity
    -12" Sony Xplod woofer
    -Majestic 400 watt amp, bridged
    If at first you don't succeed, then skydiving is not for you.
    :party:
  6. #16
    thanks guys. i'm not sure if it should be a "how to" or if someone wants to make it a sticky, but i was hoping that it helped. i see a ton of posts and threads asking about HID's so i figured if it gets put up where people will notice it then they won't have to ask as many questions.
    ROTARYENGINEPETE
    LIFT:
    18" ATX THUG WHEELS
    EBC SPORT ROTORS
    LIGHTING:
    ENGINE:
    PULSTAR IGNITORS
    OPTIMA RED TOP
    DRIVETRAIN:
    YUKON 4.56 GEARS
    CORVETTE SERVO
    TRANSGO SHIFT KIT
    Z-PACK 3-4 CLUTCH
    BODY:
    DUPONT BEDLINER
  7. #17
    bump! lol, is any of you mods out there gonna make this a sticky? thats the main reason i posted it..so ppl will have a resource for these installs
    ROTARYENGINEPETE
    LIFT:
    18" ATX THUG WHEELS
    EBC SPORT ROTORS
    LIGHTING:
    ENGINE:
    PULSTAR IGNITORS
    OPTIMA RED TOP
    DRIVETRAIN:
    YUKON 4.56 GEARS
    CORVETTE SERVO
    TRANSGO SHIFT KIT
    Z-PACK 3-4 CLUTCH
    BODY:
    DUPONT BEDLINER
  8. #18
    very awesome write up but i have a problem with mine....maybe someone can help me understand
    2003 tahoe, 55w ddm tuning HID kit w/ 6000k bulb and i purchased the wire harness w/ relay from them later as i started to have issues with one side not igniting
    after installing relay wire harness...the issue still exists on the same side but before we think bad ballast read on
    here is what i have observed, i park mine in the garage so when i start my truck, the lights want to come on due to the auto light sensor thinking its dark. I turn the key to the point right before the truck starts, here are two variances of what happens, if i wait a second for the HID lights to kick on and then start the truck, they seem to be fine. if i just go all the way thru without waiting, my driver side will not ignite and once the truck is started, I can turn the lights off/on manually to try and get the driver side back on...i get nothing on that driver side except for a flicker. When I get moving and I really get the RPM's up creating power....i can sometimes at that point get the light to come on....
    so what the hek is the damn wiring harness doing at this point? I dont think its working although I tested it by taking it off the battery and manually turned the lights on, with it connected, the lights would come on, with it disconnected, it would not.
    im super frustrated that this isnt working right! any of you guys have any insight or experience a similar issue and were able to fix it? love the lights but hate that they dont work right even after having bought the harness! GRRRRR!!!!
  9. #19
    great post could have used it when i was doing my hid research lol
    thanks for your service in the military!!
    vvme.com is the besssstttttt and cheap lol
    2007 Chevy Silverado 1500 Crew Cab
    22" Boss 313 Series
    8,000K HID Lights
    Flowmaster Exhaust
    Drop Kit
    Tinted Windows
    Blacked Out Third Brake Light
    Mond's To DO:
    Darker Tint Rear Windows
    Paint Bowtie White
    Or
    Get a Chrome Bowtie
    OLD TRUCK RIP
    2004 Chevy Silverado 1500 Ext
    Exhaust w/Chrome Tip
    2 In. Rear Shackle Drop
    Window Tint
    HID Light Kit-8000K
    22" Boss 313 Series
    Painted Front Grille & Bowtie
  10. #20
    Nice thread. VERY informative!
Similar Threads
  1. 93 V6 Sierra. Need significant performance upgrade on a budget. Advice?
    By Corverra in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-09-2010, 08:31 PM
  2. Good Performance upgrade suggestions
    By flyingtodd in forum Performance & Fuel
    Last Post: 04-25-2010, 12:01 AM
  3. next performance upgrade help???
    By npverhey1 in forum Performance & Fuel
    Last Post: 02-05-2010, 10:31 AM
  4. shocks off silverado ss performance upgrade
    By Twiztidss in forum General Classifieds
    Last Post: 08-12-2009, 12:28 AM
  5. performance upgrade
    By scottnagl in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-02-2007, 09:54 AM
