    Default Replace torque converter clutch solenoid
    ok! Need to replace torque converter clutch solenoid code (po741).I need to know if I need to drop trans or if I have access bye dropping trans pan.(2004 chevy truck 4l80e trans)
    Quote Originally Posted by RAIDER450 View Post
    Welcome aboard! P0741 is not a circuit code so changing the solenoid will not fix your problem. This code is a slip code. Your PCM is seeing a torque converter slip. You may have a converter problem or it could be a worn valve body or a false signal from the input speed sensor etc.
    Anyway if you want to change the solenoid pull the pan and the solenoid is right there waiting to be changed. It's an easy job to change it. Let us know how that works out for you.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    ok! thanks for tour time,transmission was rebuilt, replace tcc solenoid did not fix problem ,once again thanks !
    Last: 07-10-2010, 04:15 PM
  2. torque converter
    By troysakis in forum Member Introductions
    Last: 02-24-2010, 07:24 PM
  3. torque converter clutch "hunting"
    By cascott325 in forum GM Powertrain
    Last: 09-10-2009, 06:45 AM
  4. Torque Converter clutch oddity
    By universalwrench in forum GM Powertrain
    Last: 04-11-2008, 06:04 PM
  5. Torque converter [Expired Topic]
    By Davandy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-19-2006, 02:16 PM
