    Default mirrors quit heating
    03 Chev Silverado heated mirrors quit heating. I checked the fuses and switch all goodf. Help
    Yeah, I'm not sure... they want to replace the mirrors? That seems like the warming element shouldn't have gone out on the mirror.
    What are they saying is the exact problem?
    Steve
    10 Chevy Traverse LT AWD
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    If both mirrors quit working at the same time, I will be looking at the fuses first and then the wiring, switch and so on.
    Peter Smet
    Haasdonk, Belgium
    TrailLeadr's Avatar
    Jun 2005
    Coventry, Rhode Island
    You should be able to troubleshoot, and fix this yourself. Davandy has the right idea. Start with the fuse, and while you're there check for voltage at the fuse as well, then check the switches. Are both not working, or just one?
    Patrick
    Rhode Island
    Default Silverado heated mirrors both quit heating
    03 Chev Silverado heated mirrors both quit heating. Electric mirrors work, just heating or defrost not working. I have checked fuses inside and in the engine and both are ok. Controls still work but not mirror heating. How do I get access to the button in the middle of the dashboard that turns on the heated mirrors and rear window defrost.?
    Jr. Apprentice Canada's Avatar
    Feb 2007
    Elkhart, Iowa
    Does your window defrost work? Easiest way to check is at the grid connector rather than having a frosted glass.
    If so, pull the mirror glass out and check for power and ground.
    If not, check for power and ground at the rear defrost relay....check to make sure you have power coming from the dash switch and on the high side. If you have both of those, try swapping similar relays around and then checking for power back at your grid.
    -2007 Chevrolet Silverado Classic 2500HD
    -2006 Chevrolet Impala SS
    -1997 Ford Mustang Cobra
    -1996 Chevrolet Camaro Z28
    -1996 Chevrolet Beretta
  1. another heating question
    By big bopper in forum General Chevy & GM Tech Questions
    Last: 06-06-2010, 12:23 PM
  2. Heating issues
    By joker_fly in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-28-2009, 11:53 AM
  3. Heating oil for fuel
    By pontiac.79 in forum Performance & Fuel
    Last: 12-08-2008, 11:53 PM
  4. Heating and AC
    By ebollard in forum General Chevy & GM Tech Questions
    Last: 06-01-2008, 07:24 PM
  5. Silverado heated mirrors both quit heating
    By anco in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-02-2007, 02:00 PM
