Page 115 of 239 FirstFirst ... 1565105113114115116117125165215 ... LastLast
Results 1,141 to 1,150 of 2390
  1. #1141
    I purchased a Tekonsha Prodigy P3 brake controller, pulse preventer, 7-way trailer emulator, and wiring adapter for the P3 and my truck. I also took a long look at the cab as I want a clean mounting look -- instead of the ugly, tacked on mount job that most people do for brake controllers. I'm still thinking the location through and, ultimately, will need the unit in my hands to finalize it -- as the manual brake lever presents some interesting challenges; I may have to fabricate a longer one...
  2. #1142
    Just ordered Stainless Steel Nerf Bars, In channel Vent Visors and a Bug guard today.
  3. #1143
    Jr. Engineer UpsetProps's Avatar
    Mar 2012
    Calgary, Alberta, Canada
    Silicone'd the exterior trim pieces on either side of the windshield onto the windshield to stop them from "whapping" against the window at highway speed.
    Solved the extremely annoying noise coming from my A-pillars.
    - Nitto Tera Grapler 265/70R17, Line-X bed liner, Black Bowties, Stampede front deflector, DeeZee black diamond plate bed rails, TonnoPro Lo-roll cover, Antenna deleted, Spyder Projection Headlights with Phillips CrystalVision Ultra bulbs, Spyder Tail Lights & 3rd Brake Light, Rough Country leveling kit, PlastiDip'd emblems, and wheel hubs, Diablosport Trinity, 20% tint, Black OEM grill
  4. #1144
    Sr. Apprentice tyler87's Avatar
    Apr 2009
    Manitoba, Canada
    Well, headed down to Fargo, ND this past weekend and had a 6" BDS Lift installed, got it with the new springs in the back and the premium Fox Shocks... I will hopefully have my RBP RX-3 Steps in by the end of the week to replace my stainless ones.... Having a hard time posting pics so will try and get some asap
    2010 Silverado LTZ Z71
    6" BDS Lift, New springs and Fox Shocks
    Tinted Windows
    K & N Filter
    20" Fuel Off-Road Throttle Black/Machined
    33" x 12.5" x 20" Toyo Open Country M/T's
    Front and Back Bow ties Color Matched (Black Granite Metallic)
    Bushwhacker Pocket style Flares
    Weather Tech Window Visors & Floor Mats
    Blackbear Tune
    Bak Flip F1 Tonneau cover
    To Do:
    Cold Air Intake
    Corsa Sport Exhaust
  5. #1145
    Mar 2012
    Picked up a 900lb heat exchanger from the airport for a customer.
    Was surprised that the truck didn't actually look too 'sagged' in the back. Since I have the leveling kit up front I expected more sag.
    Could sure feel it in the back though.
  6. #1146
    I bought a go rhino grille guard off craigslist for my '92. Now I've got to mount it up, only problem is the bolts on my tow hooks are stuck...
    -Abram
    '76 Suburban Silverado 10 (Heavy half) 2wd
    '92 Suburban Silverado 2500 4x4
  7. #1147
    I'm the same way as you with wanting everything to look factory. I put my P3 under the dash, as low as possible and as close to my center console as possible. The bracket is screwed to the bottom of the plastic knee bolster, where it curves under and faces the floor. It's not factory, but it doesnt look bad and I'm happy with it. Check my Avalanche Mod Thread for a picture of that.
  8. #1148
    AbramJ, try soaking the bolts and nuts with PB Blaster two or three times a day for three days, then use a six point impact with a breaker bar, or use a cutoff tool, or angle grinder to cut them off. Drilling them out will be tough, and you will need titanium bits to cut high grade bolts.
    Brian L.
    Brian Larson CST. KC9DAK.
    Janesville WI.
    87 GMC G20 6.2 diesel.
  9. #1149
    I want the manual brake lever within easy reach without having to adjust seating position and without having to look down or waste time feeling around for it, so I'll be looking for a different location.
    As for what I've done to my truck, today: yesterday I received my matched spare wheel and today I had the full size spare mounted and balanced on it.
  10. #1150
    Worked some more on the under hood plastics.Click image for larger version.
ID:	41116Click image for larger version.
ID:	41117Click image for larger version.
ID:	41118Click image for larger version.
    Last Post: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & News
    Last Post: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last Post: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last Post: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last Post: 04-22-2009, 02:45 PM
