Page 161 of 239 FirstFirst ... 61111151159160161162163171211 ... LastLast
Results 1,601 to 1,610 of 2390
  1. #1601
    changed the oil (full synthetic) on my back-up vehicle (Honda CR-V) and got a new battery for it, also tried helping my dad while i was home for the weekend pull the rear wheel off of his husqvarna( however you spell it) lawnmower, no success, after hours off pounding with the sledge and using a type of pitman arm puller device, and tons of PB blast, had to give up on it, even drove the mower around hitting as many bumps and turns as possible with nothing holding the wheel on and it still would not fall off, total buzzkill
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  2. #1602
    This evening I set up two pneumatic manifolds for my OBA project. I also set up one of the two air tanks for the project. Both would be done but I managed to round off a hex plug's head on the second tank and have to figure out how the heck to get it out of there to finish off that tank. Bleah...
  3. #1603
    worked on my truck...did the following... 189K on it and running like a champ..
    ...oil change
    ...oil filter
    ...front differential flush
    ...rear differential flush
    ...transfer case flush
    ...fuel filter
    ...glow plugs
    ...cleaned air intake filter
    ...changed cabin filters
    next on the list...
    ...trannsmission flush
    ..tranns inner filter
    ...tranns spin on filter
    ...power steering flush
    ...brake fluid flush
    ...coolant flush
    06 chevy silverado 4x4 duramax 6.6L 2500HD LT-Diesel
  4. #1604
    Quote Originally Posted by lonelywolf858 View Post
    Finally got everything settled this morning. She got a 2" level kit and new shoes. Liquid Metal Rhino's on 285/70R17 AT's. I think it's a big improvement over the last set I had.
    looking good man! really like the new rims over those old ones.
    Alex
  5. #1605
    Last night I installed my Denali Headlights and ordered the HIR1 9011 bulbs. Today, I dropped it off at the trans shop to have the front diff rebuilt (hopefully under warranty). Hope to have it back in the next day or two so I can install the PS pump that arrived today (two days early!!)
  6. #1606
    drove it to work in morning rush hour traffic. I am glad I can see above cars.
  7. #1607
    May I request before/after photos of the front end of the truck prior to and then after the HIRs ... and before/after photos of what is seen at night from the cab prior to and then after the HIRs?
    As for what I did, today -- I installed a tongue box on my trailer and I cut the head off the hex head plug that was bound in the drain port of one my air tanks ... and then drilled the bulk of the material out. I've still got the fine work to do to get the rest of the plug out of the bulkhead without destroying the original threads. Bleah.
  8. #1608
    May I request before/after photos of the front end of the truck prior to and then after the HIRs ... and before/after photos of what is seen a night from the cab prior to and then after the HIRs?
    No problem. I had planned on it!
  9. #1609
    Thanks in advance!
  10. #1610
    Today I:
    • Removed my hood
    • Scuffed the underside of the hood with a scotch brite pad
    • Cleaned the freshly-scuffed underside of the hood with degreaser
    • Created a fabric pattern of the underside of the hood out of a sheet
    • Used that pattern to cut a 6ft x 4ft piece of aircraft firewall material (from www.hoodliners.net) to fit my hood
    • Used 3M #80 spray adhesive to apply the material to the hood
    • Cut an opening for the port to hood's cowl
    • Removed overspray with Goo Gone Extreme
    • Applied an autobot decal
    • Used a heat gun to set the decal since the application was in three dimensions and the material to which it had to adhere was not solid
    • Reinstalled my hood
    • Found myself a bit surprised that this took all day
    Here's a photo of the finished product just prior to hood reinstallation:
    Last Post: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & News
    Last Post: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last Post: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last Post: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last Post: 04-22-2009, 02:45 PM
