Page 162 of 239 FirstFirst ... 62112152160161162163164172212 ... LastLast
Results 1,611 to 1,620 of 2390
  1. #1611
    @SurrealOne Did you just get the material or did it come cut like the guy says he does. Also what are the decal options because that looks really awesome.
  2. #1612
    As I understand it there are pre-cut options for OEM hoods. Since my hood is not OEM I bought a 6ft x 4ft panel of the material after taking some measurements and made my own liner. You should call Gonzalo ("Gonzo") rather than email him as he seems to be more responsive to calls. Ask him about decal options if you have something in mind. That's what I did ... and he happened to have the decal I wanted.
  3. #1613
    Today I:
    • Removed my hood
    • Scuffed the underside of the hood with a scotch brite pad
    • Cleaned the freshly-scuffed underside of the hood with degreaser
    • Created a fabric pattern of the underside of the hood out of a sheet
    • Used that pattern to cut a 6ft x 4ft piece of aircraft firewall material (from www.hoodliners.net) to fit my hood
    • Used 3M #80 spray adhesive to apply the material to the hood
    • Cut an opening for the port to hood's cowl
    • Removed overspray with Goo Gone Extreme
    • Applied an autobot decal
    • Used a heat gun to set the decal since the application was in three dimensions and the material to which it had to adhere was not solid
    • Reinstalled my hood
    • Found myself a bit surprised that this took all day
    Here's a photo of the finished product just prior to hood reinstallation:
    Attachment 44970
    That looks great. As usual, good job
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  4. #1614
    You do nice work @SurrealOne
  5. #1615
    Ok @SurrealOne, I'll call him I was looking for the tahoe logo like it looks like on the moulding, a chevy bowtie and maybe Gm truck or Chevrolet all caps in 90's style.
  6. #1616
    Today I ordered the following for my OBA project: rotolock fittings, an intake filter, an OEM York dipstick, an oil return kit, two 1/4" MPT universal couplers, and 2 rubber covers for those universal covers. I think that about does it for parts. (Finally!)
    Now I need to figure out what kind of rigid tubing to use and how much of it I'll need. I also need to find a place that makes flexible metal hose to specification, as I need it for three different locations in the project.
  7. #1617
    got home from a field exercise today, and installed the 87 octane tune from a diablo intune on my truck. super happy with it so far the little bit I have driven it since the install.
    Alex
  8. #1618
    Cleaned my floor mats yesterday with some Zep's Citrus Degreaser. They needed it!
  9. #1619
    Readied my truck for winter... Installed the stock old geazer tires... And rust proofed the underside.
  10. #1620
    Quote Originally Posted by TimTom64b View Post
    What do you use for that and how do you go about it? Just curious...
    Last Post: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & News
    Last Post: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last Post: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last Post: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last Post: 04-22-2009, 02:45 PM
