Results 1,991 to 2,000 of 2305
03-11-2013, 03:12 PM #1991
I located and connected my trailer aux power and brake wire this afternoon. They were located under the brake booster wrapped up with lots of tape and held to the fire wall with a clip. Clip was an PITA to remove from the wires. After I got them free I connected the aux power to the proper terminal on the factory fuse box using an old nut from a broken aux light (finally random junk that became useful), 1/4 of my tube of dielectric grease, and some washers. Since I don't have a brake controller yet I just routed the wire in to the cab and zip-tied it out of the way.
1996 Chevy Tahoe LT 5.7L V8 4X4 199,000+ miles. Built proudly at Janesville Assembly in Janesville, Wisconsin
03-11-2013, 03:39 PM #1992
Here's a pro tip, @Conlan Rose -- you can order huge tubes of dielectric grease online from Amazon.com for about the cost of the tiny tubes at places likean AutoZone.
2004 GMC Sierra 1500 5.3L V8 4x4 SLT Extended Cab Long Bed
(Garage Link: http://www.gmtruckclub.com/forum/sho...MC-Sierra-1500)
NRA Certified Instructor, Range Safety Officer, & Benefactor Member
"I have sworn upon the altar of God eternal hostility against every form of tyranny over the mind of man." -- Thomas Jefferson
"The only difference between the topic police and the thought police ... is spelling." -- Anonymous
03-11-2013, 03:43 PM #1993
@SurrealOne I think the tube I got at Autozone was about 5 dollars and its lasted through many projects which has surprised me, but I will look in to that.
03-11-2013, 03:48 PM #1994
@Conlan Rose, I go through it like mad -- as I'm often removing and reapplying it to ground points, battery terminals, ANL fuse posts and connectors, etc. when I do a new electrical mod. Small tubes just don't hold me.
03-11-2013, 03:53 PM #1995
@SurrealOne, Recently I have began to use it a lot more and probably should use it even more than I do. I am told this is the grease you use on the door seals as well so a big tube will be very useful.
03-11-2013, 08:07 PM #1996Legend
- Join Date
- Apr 2010
- Location
- Piermont,NY, back in Northern NJ now, But may be in IL soon....
- Posts
- 4,293
Had more fun at Home Depot.. You should see the face of people when I put 4x8 plywood and sheetrock in my Avalanche..
08 Z71 Avalanche Mods to date: K&N CAI,Hellwig Swaybars and End Links, Corsa Sport Exhaust, Superchips Programer,IPCW LOF & 3rd brake light and tails, AMI Gas door,Show Hooks and Door locks, Enkei Wheels, with Pirelli tires, StreetScene Bowties, Grant Steering wheel,Muth signal mirrors,SSBC Big Brake kit,Huskyliner Mug gards,Floor mats and Hood shield, McGard Lug nuts and locks,Bedrug, Cervini's Ram Air hood,35watt HID Fog lights, Sylvania bulbs all around ZXE's Highs and Lows, WhiteNight Back up lights,Sirius and HD Radio, SnugTop painted and on, PerryCraft Rack system with Kayak and Bike Holder, Tempress Boat Hatches....
New Bilstein shocks on the way... New Mods coming soon..... X
03-12-2013, 12:17 AM #1997
I drove some friends around in it and impressed everyone with my running board LEDs and heated rear seats. And wished that the weather were good enough to take it and wash it.
03-12-2013, 04:26 PM #1998
Had my friends in the school auto shop pressure test the cooling system. They said its seems to be leaking every where. They listed the radiator and the lower radiator hose as possible culprits. Truck already has brand new radiator, hoses, and coolant. I will try to replace the hose clamps because I think they may be the problem.
My friends also complained about the leak in the roof which is really bad and me not having the handle for the parking brake..
There's a lake in my truck........ just switched out towels this will be a long night.
03-12-2013, 05:41 PM #1999
Ugh. Will covering it with a tarp help? (I'd think so if your suspicion about the roof rack mount points is correct.)
As for what I did to my truck, today -- I picked it up from the transmission mech ... complete with a new, aftermarket aluminum tailhousing from Transtar and a new, aftermarket anti-rattle pump retaining clip from Sonnax. Hopefully that'll keep the pump rub issue from cropping up, again.
I also crawled under the truck, cleaned off all excess fluid from the previous pinhole leak in the t-case, and noticed that two bolts on part of my lift kit had been undone by the mech .... and only hand tightened. (I probably would never have noticed this had I not knocked my hand against one of them and noted it was loose.) Angry, I tightened up the bolts and then checked every bolt/nut the mech might have touched to do his job. Thankfully nothing else was loose.
03-12-2013, 08:34 PM #2000
Yes it would but it would be a pain... I can't wait for warmer weather once April is here I will do the fix you described to me.
I Seafoamed my truck today.
By ZSI52 in forum General Chevy & GM TechReplies: 47Last Post: 09-03-2012, 01:32 PM -
Put the truck in the ditch today
By pmf608 in forum Chevy Truck TalkReplies: 21Last Post: 07-25-2012, 10:53 AM -
Truck died twice today...
By texas99lb in forum Chevy Silverado Forum (GMC Sierra)Replies: 10Last Post: 01-06-2010, 01:13 AM -
Truck in the shop today...
By Delmarva in forum Chevy Silverado Forum (GMC Sierra)Replies: 0Last Post: 11-11-2009, 11:39 AM -
truck over reved today?
By etpn13 in forum GM Powertrain TechReplies: 2Last Post: 04-22-2009, 02:45 PM
The Tahoe
VIGIL
Avalanche
Bookmarks
