Page 226 of 239 FirstFirst ... 126176216224225226227228236 ... LastLast
Results 2,251 to 2,260 of 2390
  1. #2251
    Thanks SurrealOne for the advice! after doing some research and looking at alot of pictures online I'm leaning towards 20% for the back window. I think that will probably be my best bet for visibility for my canopy on or off. that sucks about that carwash scratching your truck, never trusted those type of car washes. hope the repairs go well
  2. #2252
    Quote Originally Posted by vipstar View Post
    Looks like a lot of fun.
    Oh yeah, It was definitely a blast. After that week long trip of off roading and hikes, my truck has lots of scratches from tree branches and bushes. I ain't too worried about it though, the truck will get a new paint job eventually. lol
  3. #2253
    I pulled the boat out to a local lake 1.5mi from here! I set out bait traps, for next weekend fishing trip. Whisker Fishes, are waiting for me, LOL.
    2010 GMC SIERRA CREW CAB (Silver) 4x4, ReadyLift 2.5" Level Kit, 305/60/18 Dick Cepek Mud Country, Go Rhino Nerf Bars, Husky Liners front and rear, Bushwacker Bed Rail Caps, SCT Programmer.
  4. #2254
    Got these finished today.
    Mudguards from Bluex:
    and the skid plate:
    All painted up and looking nice
    [maybe I should paint "95C1500" in the skid plate
  5. #2255
    Installed new weatherstrip on both doors...no more wind noise!
    Opiewho
    2004 Silverado 2500HD W/T
    6.0L, RWD, Auto w/Towing Package
  6. #2256
    Former Member
    Apr 2012
    Reading, PA
    Yesterday I installed a second battery...
    Today I installed mini leds in the panel under the tailgate, installed a tailgate lock, installed some halogen backup lights on the backrack, installed my Wilson cell booster, and gave the torsion bar bolts three full turns.
    Tomorrow is oil change, rear diff drain/fill, and off road lights.
  7. #2257
    In the past weekend I drove about 120 miles round trip to and from camp for a work detail. Tonight the truck killed 100s of bugs on the highway and got all muddy on the trails so I will have to wash her tomorrow.
    Now 199690.5 miles on the truck.
  8. #2258
    Today I:
    • Removed the air system's annealed copper hard line everywhere except for the tank equalization line
    • Removed the rear air manifold
    • Removed the front air manifold
    • Replaced the 200psi pressure relief valves in each air manifold with 235psi pressure relief valves
    • Replaced the 140psi/175psi on/off (respectively) pressure switch in the front air manifold with a 160psi/200psi on/off (respectively) pressure switch
    • Replaced every compression fitting except those of the tank equalization line with brass push-to-connect fittings
    • Reinstalled the front air manifold
    • Reinstalled the rear air manifold
    • Re-plumbed from the rear QD to the rear air manifold with 300psi reinforced nylon tubing
    • Topped off the truck's coolant level
    Tomorrow I need to replumb the front end of the truck (front air manifold to rear air manifold, front air manifold to front QD, front air manifold to air horn valve, front air manifold to coalescing filter), pressurize the system, leak test it, and try to decide if I'm taking the air tank carrier down to re-plumb the equalization line.
  9. #2259
    Night time on the highway I can also see fine. Backing up at night is where it used to become a pain. 5W Cree LED bulbs for the reverse lights helped a -little- ... but weren't enough, so now there is a pair of Rigid flushmount Dually D2's in the rear bumper and it's like daylight behind me.
    and when did this mod happen??? I just so happened to see a chevy truck pull into one of our bays at discount tire with this mod in his stock rear bumper.... got me thinkin about it
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  10. #2260
    Washed and detailed the outside of the truck and then vacuumed the inside. Also replaced my sill trim screws because they're all destroyed.
    Last Post: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & News
    Last Post: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last Post: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last Post: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last Post: 04-22-2009, 02:45 PM
