Page 206 of 239 FirstFirst ... 106156196204205206207208216 ... Last Post byLast Post by
Results 2,051 to 2,060 of 2390
  1. #2051
    Jr. Apprentice workman482's Avatar
    Mar 2013
    L.A. (Lower Alabama)
    Attempted to refill my AC system but the high side schrader valve stuck open and absolutely would not jiggle shut. I spoke to a stealership, as the high side port did not appear serviceable. An OEM replacement is 81 bucks and is in stock, locally ... and requires replacement of the entire line from the condensor to the connection near the low side. (This also means grille removal and the like to replace the line.)
    The worst part about the situation is there's a TSB out for this .. and the replacement part STILL DOES NOT have a serviceable valve. WTF? If you know there's a problem then design a part that fixes it ... or design serviceability into the replacement solution.
    Sometimes GM makes me mad...
    Hello Surrealone, I have ran into this problem when doing a a/c service a customer's vehicle. At first I tbought the only option was to replace the entire line due to the unservicable port, but I found the a auto parts store sells a valve that screws onto the top of that one and it has a serviceable schrader valve. I think it might have been autozone, but it's been about a year since I've needed to use one. Saved the customer about $80.
    Didn't do all of this in the course of a day, more like a week of afternoons. Lol. Bought my truck about two weeks ago and noticed the parking brake wasn't holding the truck and the brakes weren't grabbing as hard as tbey were supposed to. Broke down and took the wheels off to find msjor rust pitting on all four rotors, also found uneven wear on the pads due to some rust scaling on the caliper brackets.
    I ended up replacing all four rotors, front and rear pads, new brake hardware on the front and rear, cleaned and adjusted the rear parking brakes, tbe pitman arm, steering stabilizer, and four new BFG all terrain ko's. Now he rides and brakes like new.
    Not exactly one day, but it was all done within the last week.
    "A good plan violently executed now is better than a perfect plan executed next week."
    George S. Patton
  2. #2052
    Quote Originally Posted by workman482 View Post
    I already bought the replacement part, but will remember this if the problem manifests again. Thanks!
  3. #2053
    Had the windows tinted this morning.
    * My post are intended for entertainment purposes only and should not be taken serious unless I'm posting in the Buy/Sell section of this board and all opinions are that of mine ONLY.
  4. #2054
    looks good! I applied another coat of turtle wax extreme shield wax after washing the truck and then did a full interior detail (minus the steam cleaning of the floor). I then realized that I wax it almost every time I wash it lately! Oh well, I will strip all the wax off in the early summer and start again.
  5. #2055
    Installed the replacement HVAC line between the condensor and the accumulator. The stuck high side shrader valve is no more. However, I didn't refill the refrigerant (and instead just drew a vacuum on the system and closed it off) because I'm going to have to remove the nut holting the tube in place again.
    Why? Well, the part is shaped different from the original ... and that means the studs and mount plate I had made to hold my front air manifold in place.. won't work. The new part has things in the way since it's bent differently. ARGH.
    All of this due to a stuck schrader valve that was not serviceable. A failed, unserviceable 8 dollar part is costing me hundreds. GM makes me mad, sometimes...
  6. #2056
    Towed around a trailer and now my right side flasher isn't working..... Got major hyper-flash because the rear light isn't blinking, but it is illuminated. Bulbs are brand new like I installed two or three months ago. They are silverstar bulbs rated at over 200 hours and there's no why I've driven and used the flasher that many hours.
  7. #2057
    Mar 2013
    Sorry I wasn't fast enough with my reply. Here is the part:
    autozone.com/autozone/parts/Santech-A-C-System-Valve-Core-and-Cap-Kit/2003-Chevrolet-Silverado-2500HD-4WD/_/N-jk5b2Z91uan?itemIdentifier=947262_0_9289_
    I know it's not a sponsor website but I couldn't find it on any of them.
  8. #2058
    Installed my gauge cluster that just came back from being repaired at DrSpeedometer.com, everything works great!! It's great to know how fast I am going again.
    Opiewho
    2004 Silverado 2500HD W/T
    6.0L, RWD, Auto w/Towing Package
  9. #2059
    I lied they are LongLife bulbs from Sylvania rated at over 2000 hours so wtf why is it dead.
  10. #2060
    Great info. I book market that one. Thanks
    Last: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & GM News
    Last: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last: 04-22-2009, 02:45 PM
