Page 207 of 239 FirstFirst ... 107157197205206207208209217 ... Last Post byLast Post by
Results 2,061 to 2,070 of 2390
  1. #2061
    Former Member
    Apr 2012
    Reading, PA
    Somethings I've been doing...
    Installed a new BakFlip, and redid and installed a BackRack.
    Installed some ballistic seat covers.
    Installed a Westin T-Max mount and Warn VR-12000 winch.
  2. #2062
    about halfway through on my morimoto projector retrofit! a few more days!!! im only averaging about 1 hour a day on it about 3 hours in, taking my sweet time
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  3. #2063
    How long did the Westin mount and Wench take to install? I've been thinking about getting one of those for some time...
    2006 Vortec Max 1500
    Performance:
    Other:
    -Spray-in Bed Liner
  4. #2064
    Former Member
    Apr 2012
    Reading, PA
    Quote Originally Posted by Skippy View Post
    Had it not been cold out, probably less than four hours? Its like a big jigsaw puzzle, put the pieces together, then tighten things down.
  5. #2065
    Busy day today;
    1. Replaced the leaking master cylinder reservoir & flushed the brake fluid.
    2. Flushed and refilled the rear differential fluid.
    3. Replaced the leaking oil cooler line gasket.
    4. Flushed and refilled the coolant.
    5. Replaced both knock sensors and the knock sensor harness. Finally no more Check Engine light.
    Still have a few more minor wear issues to tackle in the next week or so; 2 leaking power steering lines, worn out driveshaft centersupport bearing and that annoying noisy intermediate steering shaft. ;)
    Opiewho
    2004 Silverado 2500HD W/T
    6.0L, RWD, Auto w/Towing Package
  6. #2066
    I pulled the boat to the lake and caught 27 of these Click image for larger version.
Name:	Big Crappie.jpg
  7. #2067
    Quote Originally Posted by JimmyA View Post
    Man do I miss Crappie fishing. In Idaho, they're only about >> << big. Nothing like the slabs they have down south!
  8. #2068
    • Steam cleaned the carpet on the passenger side because of an oil spill that occurred when my vacuum pump fell over while driving.
    • Removed sound deadening material from the floor pan near where the oil pooled, cleaned what soaked into it from the floor pan, and then replaced with new sound deadening material once all oil was gone
    • Removed the top/cover from my Volant CAI system because I was sick of the powder coat on it scuffing and flaking away
    • Sanded and wire brushed said top/cover until it was free of all powder coat
    • Degreased said top/cover so that it's ready for painting, tomorrow
  9. #2069
    Yep, them slabs were heavy, 20 of the 27 were about the same size! My Sierra pulled the boat great with the extra weight. LOL
    Quote Originally Posted by steved View Post
    Husky Liners, work Great for protecting the carpet..........
  10. #2070
    Sanded and painted ball for truck today. think started out rusty as hell now its nice black. Used Rust-o-leum flat black spray paint/enamel.
    Durring
ID:	50998Click image for larger version.
ID:	50999Click image for larger version.
ID:	51000Click image for larger version.
ID:	51001Click image for larger version.
ID:	51002Click image for larger version.
ID:	51003Click image for larger version.
ID:	51004Click image for larger version.
ID:	51005Click image for larger version.
    After Cleaning
ID:	51007Click image for larger version.
ID:	51008Click image for larger version.
ID:	51009Click image for larger version.
ID:	51010Click image for larger version.
ID:	51011Click image for larger version.
    During painting
ID:	51013Click image for larger version.
ID:	51014Click image for larger version.
ID:	51015Click image for larger version.
ID:	51016Click image for larger version.
ID:	51017Click image for larger version.
ID:	51018Click image for larger version.
ID:	51019Click image for larger version.
ID:	51020Click image for larger version.
ID:	51021Click image for larger version.
ID:	51022Click image for larger version.
ID:	51023Click image for larger version.
ID:	51024Click image for larger version.
ID:	51025Click image for larger version.
    Last: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & GM News
    Last: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last: 04-22-2009, 02:45 PM
