Page 208 of 239 FirstFirst ... 108158198206207208209210218 ... Last Post byLast Post by
Results 2,071 to 2,080 of 2390
  1. #2071
    I've only had my GMC for less than a week, but the first thing I did today was to change the lock cylinder and key. I got tired real fast of having to do the "hula dance" with the ignition every time I started it. Real easy to do and way better now.
  2. #2072
    Received more switch parts!!Click image for larger version.
  3. #2073
    Nice switches, alox. Is a beer switch the same as an open container? lol.
    Yesterday I repaired the ABS system on my Yukon XL for free. No more dash lights and annoying bonging! I felt pretty good about that. Now to fix my heated seat... its a cold morning and the truck is parked in the driveway...
  4. #2074
    me and sfdefender had lunch together, then i drolled over his truck out in the parking lot for a bit. was nice.
    Alex
  5. #2075
    Filled the truck up with $100 in gas, then fixed my tail light that was acting weird seems to work now..
  6. #2076
    did a quick rewire on a ground, now my indicator light for my led off road lights works! maybe now ill remember to turn them off when i shut off the truck.
    Alex
  7. #2077
    Removed all the emblems from my tailgate then gave the 2 coats of hand rubbed Carnuba wax.
  8. #2078
    Stupidly busy weekend:
    • Adjusted tire pressure since it warmed up, substantially.
    • Removed the front air manifold bracket's mount studs and replaced with the OEM flange nuts since the replacement OEM tubing (to fix a schrader valve that was stuck open) was shaped differently and precluded me from using the just-fabbed front air manifold bracket
    • Drew a new vacuum on the AC system and recharged it
    • Worked with a mechanical engineer to plan a new mount location for the front air manifold
    • Removed all components from the front air manifold, cleaned all used PTFE tape from the ports and components, applied new PTFE tape to all components, and then replaced them all (in a different order/location on the manifold) to work with the newly-planned location
    • Removed the passenger side A-pillar cover and sun visor, ran power wire for my dash camera from behind the glove box up the pillar, into the headliner to the center of the truck, and out the same location the wires for the rearview mirror exit; once done I buttoned it all back up.
    • Mounted a FineVu CR-500HD dash camera, connected a 4.3in TFT display to it in order to aim it, and once satisfied with its point of view, tweaked its settings for daily use
    • Activated my previously-installed Power Magic Pro device to provide power to the FineVu CR-500 dash camera from my auxiliary battery any time the truck is off -- such that the camera remains on for a maximum of five days or until voltage hits 12v (whichever comes first)
    • Applied 3 coats of flat black paint and 2 coats of black, spray-on truck bed liner (for texture) to my air box cover, allowed it to dry, then reinstalled it on the truck
    • Removed the rear air manifold from the truck, removed two temporary plugs from it, and replaced them with 90 degree 1/4" MPT to 3/8" female flare swivel connectors; once done the rear air manifold was reinstalled
    • Lifted the air tank carrier into mounting position, bolted it up, and tied it in to the rear air manifold of the truck using 3/8" OD braided stainless steel hoses with 3/8" male flare fittings
    A number of photos follow. They are heavy as it relates to the on board air project work since several people have expressed interest in the on board air project. @Conlan Rose, I'm tagging you so you'll easily find this.
    FineVu CR-500HD Dash Camera (post-install):
    Volant Air Box Cover (stripped of powdercoat, degreased, and ready for paint):
    Volant Air Box Cover (post-painting):
    Air Tank Carrier (pre-installation: driver's side view):
    Air Tank Carrier (pre-installation: overhead view):
    Air Tank Carrier (pre-installation: overhead plumbing view):
    Air Tank Carrier (pre-installation: side plumbing view):
    Air Tank Carrier Installation (lift commencement using dual jacks - photo taken from driver's side):
    Air Tank Carrier Installation (lift midpoint using brick pylons for stability - photo taken from passenger side):
    Air Tank Carrier Installation (lift terminus with shims in place to allow bolt-up - photo taken from passenger side):
    Air Tank Carrier Installation (bolt-up complete, shims & supports removed):
    Air Tank Carrier Installation (plumbing from rear manifold - on passenger's side frame rail):
    Air Tank Carrier Installation (plumbing from rear manifold to air tanks - following crossmember to driver's side):
    Air Tank Carrier Installation (plumbing to air tanks on driver's side, above air tank carrier):
    Air Tank Carrier Installation (cover plate next to drive shaft installed for protection and added strength; all done)
  9. #2079
    good pics surreal! id love to see all that in person!
    i managed to drop my id inside the door in the window channel. so i learned how to take my door apart this afternoon, and retrieved my id. not super hard, but my hayes manual sure helped.
    I also went truck shopping with a buddy of mine, he is looking to upgrade (currently in a 99 Z71 reg cab) found him a 07 extended cab short bed Z71 he likes, so he was off with his CFO to see what he could swing.
    Alex
  10. #2080
    Today I ordered some fittings for the manual drain valve I'm adding to the on board air project's coalescing filter.
    Last: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & GM News
    Last: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last: 04-22-2009, 02:45 PM
