Page 221 of 239 FirstFirst ... 121171211219220221222223231 ... LastLast
Results 2,201 to 2,210 of 2390
  1. #2201
    In the last 3 days the truck got a thorough cleaning inside and out (of course it rains today), the garage and drive were pressure washed, and the I relaced the front wheel on the Harley (which is a pain).
    Sometimes the best part of my job is that my chair swivels.
  2. #2202
    Today I completed the horn toggle switch wiring in the overhead console. The regular horn button in the steering wheel now activates either the OEM horn or the electric air valve for the air horns depending on the position of the horn toggle switch.
    Next I connected the in-cab digital pressure gauge to its sending unit in the air system's front air manifold. Once done I also wired the pressure switch into the compressor slot on my custom Bussman relay box ... and pre-ran a 12v output line from the Bussman box near where the compressor will be installed ... such that hookup will be a snap when installation time comes.
    Last, I removed the bracket that supports the red plastic box which normally houses the connection between the alternator and positive battery terminal. Once done I shifted the wire positions to make room in that space for the York 210L.
    More hard line plumbing, tomorrow...
  3. #2203
    Plasti dipped wheels, came out great. Having trouble getting pics off mobile. Will update with pics when I get it figured out.
ID:	51704Click image for larger version.
ID:	51705Click image for larger version.
    I peeled the bumpers because they had too much texture, I painted them when it was a bit cold out (facepalm)
    Today I'm going to try to get the red walls touched up from winter and see if I can clear the yellow from the cab lights (since they are the only amber lights left). I'm hoping some acetone and elbow grease will do it similar to clearing plastic nobs / tac needle.
    Next weekend I'm hoping to do the chrome bumpers, then will be getting the plow moved out of the driveway to its summer home, reinstall front valence and fog lights, then notch bumper around the plow mounts for next year, then get rid of the big ol adapter mount I have in there now.
    Ext Cab 4wd LT
    Check out my garage
    http://www.NStarWindow.com
  4. #2204
    • Plumbed an annealed copper hard line from the front air manifold to the electric air valve for the Shocker XL's.
    • Removed the hard line to the front quick disconnect because it was leaking badly ... and then plumbed a new one.
    • Leak-checked the system, again.
    • Tightened all problematic compression fittings.
    • Found one compression fitting that's still leaking badly despite being as tight as it can get. (This one will have to be redone.)
    I'll get some pics, tomorrow, before I put the bumper and grille back on. No promises on uploading them, though, as it's a work day and time will be tight. Fixing that leaky fitting, getting the bumper and grille back on, opening up the overhead console and reconnecting/reconfiguring the digital pressure gauge all have priority over uploads.
  5. #2205
    Put an AC bypass pulley on the 89' Burb today. The AC hasn't worked since I got the truck a couple of years ago. I've tried a few different things to figure it out since then, and nothings worked. A week or two ago the compressor pulley started whining, and lately it's taken to intermittent screaming, so I knew it was time to change it out.
    Funny part is, when I put the new motor in a few months ago, I checked the pump's pulley and it would spin for days with one pull, so I figured it was fine. Obviously that soon changed! lol
    Decided to go with the bypass pulley since I didn't think a new compressor would change my luck with the system not working. 30 bucks compared to 300 made it easy to choose. That and AC is only needed a couple of months a year here.
    Long story short, the compressor pulley was fried, almost like it didn't have a bearing in it any longer. Now it all sounds good again, and it even feels like it runs better and has more power!
  6. #2206
    Today I:
    • Removed a bum compression fitting at the rear air manifold and replaced it with a good one
    • Re-installed the front bumper and reconnected the fogs and specters
    • Trimmed the inside of the front grille to accomodate two shocker XL bells
    • Reinstalled the front grille
    • Removed the overhead console
    • Swapped the switch positions of the OEM horn and the air horn for better aesthetics
    • Reconnected the digital pressure gauge and confirmed both its settings and that it was functioning properly
    • Disconnected the switched +12v line to the digital pressure gauge so that it doesn't flash at me due to low pressure; will reconnect this once the compressor is installed
    • Blew a fuse when disconnecting the switched +12v line from the digital pressure gauge because I was tired and careless with contact
    • Replaced the blown fuse which was stupidly easy to spot thanks to having put EasyID fuses into the truck
    • Reinstalled the overhead console and tested all switches for proper function
    • Used an external 6hp air compressor to bring the on board air system to 120 psi
    • Let off a few test blasts of the air horns -- which really put a smile on my face
    • Brought the engine up to operating temperature and checked the transmission fluid level
    • Added transmission fluid to replace what was lost when the transmission cooler was removed for air horn installation
    • Lamented that the pollen is still coming down, as my truck is filthy and I still can't detail it
  7. #2207
    Looks awesome surreal. Really stealthy.
    I ended up with some free time last night so I got my front valence and fogs reinstalled. Now just to notch the bumper so I can get the plow on and off without removing it all.
  8. #2208
    Today I installed the Spectre CAI and the Diablo InTune 87 octane with hard shifts tune on the 2007 GMC Sierra and I'm impressed. Want to thank Lew for all his help and answering all my emails before buying the I-1000 from him and now I can't wait for him to write me a custom tune once my truck learns the 87 octane tune.
    * My post are intended for entertainment purposes only and should not be taken serious unless I'm posting in the Buy/Sell section of this board and all opinions are that of mine ONLY.
  9. #2209
    I got my new shocks in today and installed them under my carport with a storm going on, Fun Fun...... I got the Bilstein HD performance. I took it for a small test drive after install and even though it was raining I noticed a big difference just crossing the railroad tracks and I am very happy with the purchase. My hood also came in at the body shop and I went and got the red paint mixed. Hopefully it will be ready next week.......
  10. #2210
    Getting more quotes on a rack and pinion + power steering pump replacement.... quotes are all over the board..... anywere from $850 (including alinement) to $1300.....
    Anyone know what it should cost to do that? I am 2 wheel drive, so there is no transfer case in the front.
    Last Post: 09-03-2012, 01:32 PM
    By pmf608 in forum Chevy Truck Talk & News
    Last Post: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    Last Post: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    Last Post: 11-11-2009, 11:39 AM
  5. truck over reved today?
    Last Post: 04-22-2009, 02:45 PM
