Results 1 to 10 of 10
    Master Mechanic Silverado Junkie is a glorious beacon of light
    Feb 2010
    Lead Hill, Arkansas
    Default Urea Injection
    How easy is it to disable urea injection on 2011 Duramax?
    1995 Silverado,Z71, 3-inch lift,2-inch leveling kit, SkyJacker Suspension, short ram-air intake, throttle body spacer, MSD ignition coil, straight pipes
    Legend 1st Synthetics is a name known to all
    Feb 2009
    Nationwide
    You will not be able to disable it. The government mandates once you run out of it the truck will only go so far and under reduced power. As of now this is what I am hearing. Could change though.
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Sr. Engineer Joeairforce is a name known to all
    May 2009
    Maryville, TN
    1 Post(s)
    Quote Originally Posted by Silverado Junkie View Post
    Check into a program called "EFI Live". I don't know if they cover the 2011's yet, but it is a program that you use that can reprogram/tune the ECM with.........
    Joseph - 1989 Chevy Suburban V2500, 4x4, 6.2L Diesel, 4L80E Auto Transmission
    Under the knife
    Airforce Veteran (7 years)
    NRA Life Member
    Feb 2010
    Lead Hill, Arkansas
    OK thanks guys because if i got one, id get rid of all the emissions junk the government makes manufacturers install.
  5. #5
    Jr. Engineer Loggerhead Mike is a glorious beacon of light
    Aug 2009
    Franklin, NC
    why would you want to take the piss bucket off? lol
    GM TECH
    05 silverado shortbed
  6. #6
    Feb 2010
    Lead Hill, Arkansas
    For the same reason you would, its too much maintinance and it gets in the way of performance mods such as putn a straight pipe on that baby.
  7. #7
    Aug 2009
    Franklin, NC
    lol. i hear ya. im still curious to see how much a bottle of that piss water is going to cost
    I beleave that program is going to be in ROM. May have to look into shorting the sensor to make it think its full all the time
    GM TECH
  8. #8
    Jr. Engineer Jacqson is a name known to all
    Jan 2009
    North Vancouver, BC
    What kind of performance are you looking for? These things come with 397 Hp and about 765 ft lbs of torque. Manufacturers are making it very difficult to alter pollution controls and it might cause you more problems then it's worth to try and remove it, plus you're going to possibly void your warranty and I know I wouldn't want to pay a repair bill on a Dmax. Just my $0.02
    2011 Chevy Silverado 3500HD, Taupe Gray Metallic, Line-x over the Rail
    "Suburban" There is no Substitute.
    For Sale- My Loaded up 02 2500 Suburban
  9. #9
    Feb 2010
    Lead Hill, Arkansas
    I agree with you, they are powerful. But i love the way a straight piped diesel sounds and i love sein them fill up the road behind them with a cloud of black smoke.
  10. #10
    Legend murdog94 has a reputation beyond repute
    Feb 2008
    Cloquet, Minnesota, United States
    i disagree, while the black smoke is cool you are looking at motors that are more efficient and run better and quieter than any motor on the market. Yes they suck but i do know that there are plenty of manufactures out there who are working on ways to get more out of them with out touching the emmisions. As well as putting nice loud pipes on.
    Ive worked on Diesels for years and dont have a clue what to do to the new ones. But when i jump into a 1995 K3500 with the 6.5L turbo and drop $10K in mods into it and then throw it up against a 2011 duramax and still get spanked its hard to argue... (this is hypothetical i run a gas engine because i couldnt find what i wanted with a diesel)
    But you get my point.
    Mike
    Currently
    2002 Ford Taurus SES (daily beater)
    1997 Chevy S-10 Blazer 4X4 with 326K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2004 Dodge Ram 4X4 (tow rig)
    "Hold it to the floor till you see God.... Then Brake!!!!"
Similar Threads
  1. Fuel injection on an 84 1/2 ton
    By PrestonM in forum Chevy C/K Truck Forum
    Last Post: 09-05-2009, 10:54 AM
  2. Tune Port Injection
    By ki4kma in forum The Coffee Shop
    Last Post: 07-08-2009, 09:00 PM
  3. Injection Cleaning?
    By bkdraft in forum Performance & Fuel
    Last Post: 01-15-2009, 10:46 AM
  4. Air Injection.. a little help
    By vncj96 in forum Chevy Truck Accessories
    Last Post: 12-07-2008, 07:01 PM
  5. injection systems ? [Expired Topic]
    By 2loud in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-20-2006, 11:29 AM
