    Default Encoder sensor replacemente?
    I searched the threads... I have an 04 Sierra Z71 with the 5.3
    I think my encoder motor is bad. I replaced the push button swtich and it acts the same...
    The truck will engage in 4wd if I turn the truck off for a min, and select 4wd hi/lo or auto
    after the truck runs for a few minutes the "service 4wd" light comes on.
    I want to try replacing the Sensor first before trying anything else. My OBDII scanner wont pull any codes on it.
    Does anyone have instructions on replacing the sensor?
    Thanks.
    Morgan Trotter
    Southern California
    pull your t-case shield and front prop shaft off. 3 bolts and its out
    GM TECH
    05 silverado shortbed
    TrailLeadr's Avatar
    Jun 2005
    Coventry, Rhode Island
    From what I get out of a bad sensor is that it will generally throw a code of C0327. If there's no code it sounds more like a bad motor.
    Patrick
    Rhode Island
  1. How To: Encoder Motor Sensor Replacement
    By Mtrotter in forum GM Electrical Tech
    Last: 12-02-2011, 02:37 PM
  2. Encoder Motor Filling with Oil
    By Mtrotter in forum GM Powertrain
    Last: 05-10-2010, 05:59 PM
  3. Encoder Motor Replacement
    By Higgie in forum GM Powertrain
    Last: 11-25-2009, 07:40 PM
  4. Encoder Motor and Alignment Questions
    By BlackPearl in forum GM Powertrain
    Last: 04-18-2008, 12:15 PM
