Results 1 to 2 of 2
Thread: Door Adjustment
    Default Door Adjustment
    I've a door, driver's side, which is only slightly out of adjustment. Like someone had it off once and put it back on almost right. It works pretty well, but is just enough of a tug to be annoying.
    If I were to attempt to re-adjust this door, what would be the proceedure?
    btw, how can I tell if the misalignment is due to position or something being bent? It's just odd enough that perhaps it's a warping from someone swinging on it or such.
    _____________________________________________
    1991 Chevy C1500 S/W Std Cab 4.3L V6, 5-spd Manual
    I'm pretty sure its just the two pins holding the door on there. When I go off roading mine kinda pops up so I have to lift up on the door and push it back into place which puts the door right back in adjustment. Obiously I need to change my pins out... perhaps you might need to do the same.
  1. window adjustment
    By gargoyle725 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-29-2009, 06:26 AM
  2. torsion bar adjustment
    By badbowtie12 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-25-2009, 03:18 PM
  3. valve adjustment?
    By sparky09 in forum GM Powertrain
    Last: 02-18-2009, 09:05 AM
  4. tie rod adjustment
    By skipbeau3790 in forum Member Introductions
    Last: 11-02-2008, 10:36 AM
  5. Fender Adjustment
    By Trex in forum Chevy Colorado Forum (GMC Canyon)
    Last: 05-12-2008, 03:48 PM
