GM Truck Club
Page 2 of 5 FirstFirst 1234 ... Last Post byLast Post by
Results 11 to 20 of 48
  1. #11
    Master Mechanic Silverado Junkie's Avatar
    Feb 2010
    Lead Hill, Arkansas
    Seafoam works awesome in your fuel. It cleans out your entire fuel system. But when it comes to your oil, the only additive i'd ever put in my oil is Lucas Oil Stabilizer. It cant be beat.
    1995 Silverado,Z71, 3-inch lift,2-inch leveling kit, SkyJacker Suspension, short ram-air intake, throttle body spacer, MSD ignition coil, straight pipes
  2. #12
    Sr. Engineer ahm1127's Avatar
    Jan 2009
    Pennsylvania, United States
    Thanks for the info, I have been thinking of using the seafoam but now I will.
    Everyday I wake up is a great day! ;-)
    05' Chevy Suburban, 11' Ford Fiesta
  3. #13
    Jr. Engineer
    Mar 2010
    Cochrane, AB
    Quote Originally Posted by ahm1127 View Post
    Use it in EVERYTHING! In some of my older snowmobiles it has even dulled down or removed the pinging sound from the engine!
    SEAFOAM, I PUT THAT @#!$ IN EVERYTHING!
    2004 Silverado LS 5.3L Z71 Crew Cab
    260,000+ km
  4. #14
    Jr. Apprentice
    Mar 2010
    Sugar Grove, IL
    Wow, I've never even thought about using seafoam. Is it only for older trucks?
    2008 Chevy Silverado Z71 Black Regular Cab Short Bed
  5. #15
    Jr. Engineer
    Mar 2010
    Cochrane, AB
    Quote Originally Posted by dwalsberg View Post
    Definitely not. Carbureted or Fuel Injected. Use it. I swear by it. If you are skeptical, use a small amount at first, then WHEN you notice a difference, put in the recommended amount.
    Lawnmowers, quads, snowmobiles, cars, trucks, motorcycles, snowblowers
    I've used it in all and have nothing but praise.
  6. #16
    Jr. Engineer
    Mar 2010
    Cochrane, AB
    It's not to be used EVERY time you fill a tank of gas... I generally use it in the last two tanks of my snowmobile before storing it for summer, and the last two tanks of my boats before storing them for winter.
    I also put a can in mid way through the season and possibly once again IF I am running the machines alot.
    Put it in your truck every 3, 4, 6 or 12 months... it's up to you and also depends on how old the engine is. (Older usually using it more often)
  7. #17
    seafoams good stuff but probably not the entire fix for your ruff idle
    open the butterfly valve on your throttlebody and see how much carbon ya got in there. A quick trick but not a complete fix is to hold that valve open and spray a can of choke clean inside. wipe out all you can, when you go to crank the truck hold the pedal at WOT so you dont get a backfire. again not as good as a regular carbon clean service but it will help alot. May not be to noticble but if you monitor your fuel trim before and after you do it you'll see
    GM TECH
    05 silverado shortbed
  8. Likes cmcolfax liked this post
  9. #18
    Jr. Engineer
    Mar 2010
    Cochrane, AB
    Quote Originally Posted by Loggerhead Mike View Post
    There's a seafoam product for THAT too!
    http://www.seafoamsales.com/how-to-u...oam-spray.html
    http://www.seafoamsales.com/sea-foam-spray.html
    lol I swear I don't work for Seafoam, just really like the product!
  10. #19
    never seen that before. thanks buddy
    i stand by the stuff too, use it in the mower, 4wheelers ect
  11. #20
    I think I'll give this a try today. I used BG fuel injector cleaner, stuff that gets sucked straight into the fuel rail after you disable the fuel pump.. after that I cleaned the TB and that all seemed to make an enormous difference.. but I still have a slight stumble at idle like an injector is stumbling. Its like $7-8 a can, so its worth a try to get the rest of the carbon out of the parts that the fuel system never touches.
    But at the same time I've heard you're supposed to do the plugs after you suck Seafoam through the vacuum line...?
    03 1500 Z71 5.3 - DD/Tow rig
Similar Threads
  1. What have u done to ur GM truck today?
    By devilsalmostfree in forum Chevy Truck Talk & GM News
    Last: 06-07-2013, 05:01 PM
  2. Put the truck in the ditch today
    By pmf608 in forum Chevy Truck Talk & GM News
    Last: 07-25-2012, 10:53 AM
  3. Truck died twice today...
    By texas99lb in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-06-2010, 01:13 AM
  4. Truck in the shop today...
    By Delmarva in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-11-2009, 11:39 AM
  5. truck over reved today?
    By etpn13 in forum GM Powertrain
    Last: 04-22-2009, 02:45 PM
