    Default Rancho Quick Lift Loaded or Bilstein leveling struts???
    I have the RC 2" leveling kit with blocks in the rear of my 07 NNBS Silverado 4x4. I am wondering if anyone has used the Rancho "Quick lift loaded" and has some feedback as to ride quality and how it compares to the bilstein leveling struts using the stock springs. I know the Rancho has adjustable struts from soft to a stiffer feel but not sure what they are doing as far as the springs they are using on the Quick Lift loaded, I do not want to ruin the factory ride like when it ws new. My ride has 41000,00 miles on it and I can feel the difference from when it had a few thousand, it does not take pot holes and bumps very good anymore at all and after I installed the RC front 2" spacers it seems to have alot more body lean when conering and on the hihway in the wind the sway is worse which by leveling only 2" I would not think would be an issue. I am thinking the sway and lean would be much improved with new front struts and/or a quick lift loaded with the springs ..
    I'd get the Bilsteins because it does use the stock spring.
    Newbie
    May 2011
    Newberry Springs, California, United States
    i just ordered the quick lift loaded has coil already on ready to bolt up. whenever i figure this site out i will put some before and after pics up and. Just curious did you bolt the sway bar back on after you installed the spacers? that may be why its leaning more
  1. Rancho Quick Lift
    By at4rxj in forum Lifted & Offroad Suspension
    Last Post: 06-26-2011, 10:48 PM
  2. rancho quick lift plus spacer?
    By blkz71 in forum Lifted & Offroad Suspension
    Last Post: 05-18-2011, 05:21 PM
  3. Bilstein 5100 + Standard Leveling Kit = ????
    By Vincennes02261897 in forum Lifted & Offroad Suspension
    Last Post: 12-20-2010, 10:12 AM
  4. Bilstein 5100's vs Rancho RS5000
    By 1flyfisher in forum Lifted & Offroad Suspension
    Last Post: 11-15-2010, 09:22 PM
  5. Bilstein 5100 leveling shocks?
    By Mustang Bob in forum Lifted & Offroad Suspension
    Last Post: 03-22-2009, 04:28 PM
