Results 1 to 9 of 9
    Cool Easiest way to turn off check engine light
    I do my own oil changes and i dont know how to reset my check engine light. Any simple answers to that other than bringing it to the dealer?
    thanks,
    Taylor
    '03 Silverado 4.8 v8 4x4
    Quote Originally Posted by Chevy350 View Post
    thanks,
    Taylor
    Hi Taylor, If there is a hard code stored you will not be able to clear it. Rather than disconnecting the battery which clears all your engine, transmission and Powertrain adapts as well as radio presets, etc why not take it to Autozone? They will tell you the code or codes and you can go from there. When your check engine light is on usually your PCM has initiated some failsafe measures to protect whatever component that is acting up. Clearing the code may actually cause more damage to that component. If you have no Autozone around call a few shops. Many will scan your truck for free.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Quote Originally Posted by Jimmiee View Post
    I have an Autozone 8 miles away, I will go visit them this weekend then. Thanks a lot jim
    And just to be clear you are talking about your Check Engine Light and not your oil change light, correct? You can turn off the oil change light by turning on the key without starting the engine and press the gas pedal on and off 3 times within 5 seconds.
  5. #5
    Sr. Apprentice
    Jan 2009
    Dixon, IL
    there are also OBDII readers you can buy off the tool trucks(snap-on, matco, mac) ive got one and they are the greatest! you can read codes and it will break them down in to english.. mine cost me about 75 dollars, but its a plg and play. you can get some that are hundreds of dollars, but as the price goes up the amount of functions and things you can change go up as well!
    2006 gmc sierra 1500 z71
    flowmaster 40 series cat-back system
    S&B cold air intake
    1970 chevy c10 350/290 crate engine
    dual flowmasters to dual outlet in front of the rear tires
    HAD a 99 Harley Sporster 1200
    after market paint job
    lotsa chrome
    screamin eagle pipes
  6. #6
    well its the orange picture of an engine... not in words "check engine" if thats what you mean
    '03 Silverado 4x4
    Cold air
    7' Fisher Minute Mount 2
    Working on a leveling kit from ReadyLift
    "If its free, its for me!!"
  7. #7
    Quote Originally Posted by black98noma View Post
    Thats pretty cool, ill look into that... thanks man!
  8. #8
    I did the change oil reset trick and the light is still on. I brought it to a friend who has a code reader and its for the oil but how can i reset it? do i have to see a dealer?
  9. #9
    Still not sure which light is on?? The oil light should be reset with gas pedal. The check engine light would have specific codes like a P0123 or a P0456, etc. You didn't say if it had any codes???
Similar Threads
  1. Check engine light on.
    By Andy7 in forum Performance & Fuel
    Last Post: 07-16-2010, 01:26 PM
  2. Check engine light came on????
    By vncj96 in forum General Chevy & GM Tech
    Last Post: 05-12-2009, 10:27 PM
  3. check engine light
    By Custom04Chevy in forum General Chevy & GM Tech
    Last Post: 02-10-2009, 01:35 PM
  4. Check Engine Light
    By RAM717 in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 10-17-2007, 04:24 PM
  5. check engine light
    By ss_silverado_phoneix99325 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-04-2007, 08:57 PM
