Results 1 to 10 of 12
    Feb 2010
    Homerville GA
    Default help with wheels please
    ok. im sure im going to get 20x9 xd badlands for my truck , just not sure which offset i should get. i understand how the offset works and all but still not sure which is best.
    it seems to me like the (-) offset would be less likely to scrub than the (+). any help would be appreciated. so negatives scrub less? badlands come in -12 and +18 offset. thank u
    Jr. Engineer sharpshooterusmc's Avatar
    Mar 2010
    Camp Pendleton, CA & Opelousas, LA
    the -12 will stick out about how u wheels are mow, maybe a little more while the +18 will ne tucked way under and imo
    Quote Originally Posted by ethan1029 View Post
    Not necessarily true. Negative offset pushes the wheel out which can also lead to rubbing. I ran into this with my wheels. I went with a zero offset when I should have gone with a positive offset to keep it from rubbing when I turn.
    Bobby - North Carolina
    2008 4x4 5.3L V8
    6" Suspension Lift and 1.5" Body Lift
    20x9 Ballistic Jesters w/35" Toyo Open Country MT's & 1.5" rear wheel spacers
    4:56 Yukon Gears
    Hypertech Speedometer Calibrator
    Baja style bed mount spare tire carrier
    Flowmaster 40 series dual exhaust
    Recon Smoked LED tails/3rd brake lights/black projectors w/switchback LED's in the corners
    N-Fab Nerf Steps
    K&N CAI
    No Fear Pedals
    Tint, Line-X bedliner, Window visors, Rear wheel well liners
    Painted front grill, bow ties and door badges, de-"lettered" tailgate
    Powder coated front and rear bumpers
    It also depends on tire size. What size tire are you gonna run?
    IF YOU AINT FIRST, YOUR LAST!
    2003 GMC Sierra 1500 Z71
    K&N Intake
    Flowmasters
    6K HID Lows, Highs, Fogs
    3 Piece Billet grille
    De-badged
    Autopage Remote Start
    3000 Watt Stereo System
    Truxedo Bed Cover
    3 Inch lift
    33x11.5 Nittos
    18" Weld Wheels
    Feb 2010
    Homerville GA
    plannin on runnin 35" inch tire
    Ill sell you some 20s. I want some black KMC Rockstars
    Stock offset is +31mm, so use that as your baseline. -12mm will push the tires out approx.1 3/4 inches, +18mm will only push them out about 1/2 an inch. (13mm = 1/2") So the best thing to do is go out and turn the wheels to full lock in both directions and do some measuring , on the inside of the tire and out. And take into account the tire width and possible suspension travel, and also what the lift kit you are using requires. Some kits specify certain offsets so the tires don't rub on the new suspension components.
    Adam
    So, what lift kit do you have installed?
    Mark
    2007 Black Silverado LTZ Z71 4x4 Crew Cab, 5.3L, Airaid MIT and K&N Filter,
    Corsa Sport Exhaust, Rough Country 2" Leveling Kit, Removed Front Air Dam,
    N-Fab Steps, Line-X Bedliner, Truxedo LoPro QT, Carriage Works Billet Grill,
    18x9 Helo 835 Machined Black Rims, 285/65/18 Nitto Terra Grapplers
    Time to slow down on the mods! Running out of money:neutral:
    Feb 2010
    Homerville GA
    wat kind of 20s do u have for sale?
    Feb 2010
    Homerville GA
    and i have the 2 1/2 inch rc leveling kit. got it for $189. im running 35x12.5/17 on stock rims now but since the 35s on stock rims dnt rub at all im pretty sure i can fit 35s on 20s with minimal scrubbing if i get the correct offset
  1. wheels
    By silverado454 in forum Lifted & Offroad Suspension
    Last Post: 03-18-2010, 12:22 AM
  2. 4wd and 2wd wheels
    By RATRODKING in forum Lifted & Offroad Suspension
    Last Post: 08-29-2009, 09:41 AM
  3. Wheels are they gone? Can they look any better?
    By a_leggio in forum Lifted & Offroad Suspension
    Last Post: 07-20-2009, 10:44 PM
  4. Wheels
    By Jarrad in forum Lifted & Offroad Suspension
    Last Post: 06-28-2009, 11:18 PM
  5. TRADE chevy 20" chrome wheels for other chevy 20" wheels
    By 07RedVrtecMAX in forum General Classifieds
    Last Post: 01-28-2009, 07:47 PM
