    Default Washer fluid not spraying
    1991 Silverado 1500. I just bought it. The wiper fluid does not spray out. Yes there's fluid in the reservoir. When I depress the button, no fluid and I don't hear any mechanical noise like its not trying to pump it.
    The wipers work. Lights and turn signals work.
    What's the first thing I should look at?
    thanks -
    80s
    get a test light and unplug the washer pump connector have some one press the washer switch and touch the two probes if it lights up you have power if no light then start tracing wires, if you have power and can not hear the washer pump replace it
    if you hear it look for broken washer lines
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    There is a fuse and a relay for the washer pump. take a look there ...
    Pavement sucks... :grrrrrr:
    1994 K1500 4x4 Ext. Cab
    PCM chip and Xenon 8000k bulbs
    350cu.in bored over .050"
    balanced Crank, 10:1 compression
    Flat top pistons,cam,ported heads
    Option Racing Cold Air Intake
    Holley Throttle Body Spacer
    Accell Igition, 45kv coil
    FloTech Headers, no CATs, dual exhuast
    Goodyear Silent Armor A/T 305/70-16
    Pioneer SupertunerIII CD USB Bluetooth
    Kicker ZX200.2 ZX Amp
    Kicker Audio COMP 10" Subwoofer
    Quote Originally Posted by Z71_guy View Post
    Problem fixed. I took a test light, tested the pump connector and determined that there was power. I turned on the washer and listened to the pump and determined that it was making noise. It was at that time I noticed washer fluid leaking out from under the truck, so I figured there was a broken or disconnected hose. I took off the wipers and the plastic grill thing underneath them. There there were both hoses disconnected.
    Thanks for your help and good suggestions.
    Sorry, I should have suggested that. I had the exact same problem.
    Glad the issue is resolved.
    Now its time to go off-road and get her dirty...
  1. Washer fluid for rear window?
    By bruceb3 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 04-20-2011, 04:30 PM
  2. frozen washer fluid lines
    By Ohio Tahoe in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 12-16-2009, 03:15 PM
  3. Windshield Washer Fluid Pump
    By meash20 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-08-2009, 09:34 PM
  4. Washer fluid inoperative 04' colorado!
    By PencilPro in forum General Chevy & GM Tech Questions
    Last: 08-12-2009, 08:16 PM
  5. Windshield Washer Fluid System
    By SilveradoBrett in forum General Chevy & GM Tech Questions
    Last: 12-08-2008, 06:34 AM
