    Default How to remove a water pump
    I have an 01' Tahoe and need to replace the water pump. But I have been told I need an air chisel to remove the fan clutch? Any help would be great.
    2001 Tahoe 5.3
    Cool how to remove a water pump
    Theres special tools to remove the fan and its NOT a air chisel.Check auto parts stores for the tools, some will loan or rent them to you.
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Quote Originally Posted by BigFish View Post
    2001 Tahoe 5.3
    There is a simpler tool you can use, but be careful. I removed my fan clutch assembly off my 98 4.3L Silverado and had the same issue removing the fan clutch. Took it to a friend of mine and he used a dull chiesel about 12" and placed it near on edge of the fan pulley large nut and with a ball peen hammer tapped the chiesel I think clockwise and it was enough to loosen it up. It took him three tries and problem was solved.
    If you haven't gotten it off yet, this might be the easiest way. Be careful and make sure the chiesel has a blunt edge so it won't damage the large nut.
    Nov 2009
    Grandview, WA
    You will also need a strap or chain wrench to hold pulley. I just replaced my water pump.
  1. 1983 Water pump
    By Bcbp14 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-28-2010, 11:51 PM
  2. How do I get the fan off to replace water pump
    By phoebeisis in forum General Chevy & GM Tech Questions
    Last: 01-12-2010, 02:32 PM
  3. water pump replacement
    By bowtiebrian in forum General Chevy & GM Tech Questions
    Last: 04-28-2009, 12:07 PM
  4. Truck water pump on a 454
    By larry kaas in forum GM Powertrain
    Last: 02-09-2009, 08:09 PM
  5. WTB: Water pump
    By 95burban in forum General Classifieds
    Last: 01-11-2009, 04:15 PM
