    Default 1996 5.7 running rough
    i have a 1996 chevy k1500 5.7. i recently installed a comp camshaft since then my truck idles rough and has a sputter at initial throttle but smoothes out.it is throwing a muti missfire and throttle position senor low circuit code.what could be the cause of it?
    Sr. Apprentice black98noma's Avatar
    Dixon, IL
    sounds like a timing issue...
    2006 gmc sierra 1500 z71
    flowmaster 40 series cat-back system
    S&B cold air intake
    1970 chevy c10 350/290 crate engine
    dual flowmasters to dual outlet in front of the rear tires
    HAD a 99 Harley Sporster 1200
    after market paint job
    lotsa chrome
    screamin eagle pipes
    X2 sounds like timing to me too.......
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    When setting your timing, be sure to disconnect the computer.
    On my '94 K1500, it was located behind the dash and underneath the glove box.
    I believe it is a brown or tan wire with a black stripe.
    Once it is disconnected, set the distributer timing at 0 degrees.
    Then after connecting the computer back up, the timing should readjust itself.
    Good luck...
    Pavement sucks... :grrrrrr:
    1994 K1500 4x4 Ext. Cab
    PCM chip and Xenon 8000k bulbs
    350cu.in bored over .050"
    balanced Crank, 10:1 compression
    Flat top pistons,cam,ported heads
    Option Racing Cold Air Intake
    Holley Throttle Body Spacer
    Accell Igition, 45kv coil
    FloTech Headers, no CATs, dual exhuast
    Goodyear Silent Armor A/T 305/70-16
    Pioneer SupertunerIII CD USB Bluetooth
    Kicker ZX200.2 ZX Amp
    Kicker Audio COMP 10" Subwoofer
    x2
    with the wire still connected your comp will go into default mode
    GM TECH
    05 silverado shortbed
    i got a t.p.s. and that fixed the rough idle but i still has the sputter i will take a look at that tomorrow thanks for the input.
    murdog94's Avatar
    Clean your I.A.C as well..... That can cause a sputter...
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Running Rough!
    By cwarrenburgess in forum GM Powertrain
    Last Post: 05-03-2010, 01:18 AM
  2. Rough running 99 burban PLEASE HELP!!
    By bferland in forum General Chevy & GM Tech Questions
    Last Post: 08-18-2009, 09:39 PM
  3. rough running
    By heaviechevie in forum General Chevy & GM Tech Questions
    Last Post: 10-16-2008, 05:05 PM
  4. 94 Suburban running rough..HELP
    By AllenH60 in forum GM Powertrain
    Last Post: 08-04-2008, 01:50 PM
  5. Rough running when cold out
    By bartle00 in forum General Chevy & GM Tech Questions
    Last Post: 01-18-2008, 11:30 AM
