Results 1 to 10 of 15
    Default Disabling auto locks
    I have a 99 LS Silverado and want the auto locks disabled, there isnt anything in the owners manual about it. Can someone point me in the right direction?
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    I look in my wife's 02 Burb manual when she gets back. It should be the same process, right?
    It's a series of off-run-off-run, rub your left ear, spit east... something like that.
    1999 Chevy K2500 Suburban 350
    murdog94's Avatar
    Quote Originally Posted by KidHauler View Post
    Yep if it can be done... but you forgot to kick the left quarter panel with 5lbs of force.....
    To be honest i dont think that you can disable that function since it is a safety feature, similar to the drivers air bag.. but i could be wrong.. I dont remeber anything in my 02 Silverados owner manual.
    Mike
    Currently
    2011 F-150 Crew 4X4
    i could do it on my old GP. On my brothers 01 it will open the doors when you turn the ignition off but mine stay locked even when the key is removed, its annoying as hell
    murdog94's Avatar
    I see your point my F-150 did the same thing... quite irritating...
    There is a way, it's a series of things, when you turn your key on but not start the engine, then it has to do with your turn signal, and brake pedal or something. My dad was just talking to me about this.
    www.youtube.com/ippielb
    I didn't think you could do this on the 99's. At least thats what i've been told. I have one and I'm not aware of it anyways. But if there was that'd be great
    Dang my wife is busy - I finally got into her truck.
    This is from the '02 Suburban manual. I don't know if it'll work for you, but lets hope so.
    To turn off auto locks:
    With ignition OFF, pull multi-function switch toward you until flash-to-pass is activated, and hold during next step.
    Turn key to RUN and OFF twice. With key in OFF, release the multi switch. Doors should lock then unlock.
    Now turn your attention to the door panel power lock button - push the lock side twice.
    That's it. My guess is, if you turn the key twice and let go of the multi switch, and nothing happens, it probably isn't set up the same.
    Good luck gang,
    murdog94's Avatar
    Wow you dont have to do a line dance and burn a tree down???
    Good luck gang,
    I found this, it is similar to your function. It is for the 2000 Silverado. One of these should work.
    1. Pull back on turn signal/multifunction lever, all the way toward you and hold it while performing the next step.
    2. Begin with ignition in OFF, turn your key to ON. Return to OFF and turn to ON again. Then return it to OFF. Once you do this you will hear the lock switch lock and unlock.
    3. You are now ready to program the auto locks.You will have 10 seconds to program once you release the turn signal/multifunction lever.
    4. Press the unlock side of the lock switch on the driver's side door panel 3 times to turn off the atuo door lock feature. No doors will lock or unlock.
    You can exit the program mode any time by turning the ignition to ON.
    Paul
  1. Disabling auto headlamps.
    By vncj96 in forum General Chevy & GM Tech Questions
    Last: 06-15-2010, 08:09 AM
  2. Disabling DRL's?
    By redfan13 in forum GM Electrical Tech
    Last: 01-15-2010, 06:54 PM
  3. Auto door locks on 97 k1500
    By Cottini K1500 in forum Chevy C/K Truck Forum
    Last: 05-01-2009, 12:09 AM
  4. Tire pressure sensors... disabling?
    By 07WT in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-03-2007, 05:56 PM
  5. Disabling DRL
    By KingScyld in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 01-06-2007, 11:04 PM
