Thread: Sqeaky leaf
    Default Sqeaky leaf
    The leaf springs on my 95 burb are rubbing each other and sqeaking. I sprayed grease between them and that worked until the grease washed off. Any ideas on a permanent fix?
    1989 Pontiac Bonneville LE
    1995 Pontiac Bonneville SE
    1995 Chevrolet Suburban LS 1500 4x4
    2000 Pontiac Bonneville SSEi
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    A dry lithium grease might last longer. On an old nova, I used some poly spring pads like these that helped. I don't know if anyone makes them for GM Trucks.
    High Desert SoCal
    02 Honda Civic LX
    I found this stuff that's a dry lube. It's exactly like lead from your pencil, well, kind of. But it works really good, and stays there for a while. What some people do is cut up those plastic flexible binders and put them between each leaf. Maybe if worst comes to worst.
    www.youtube.com/ippielb
    On rock crawlers it's popular to place teflon pads between each spring to reduce squeeking.
    You can also lift the truck and "fan out" the spring pack and wash it out real well then sprinkle in ground up pencil lead (graphite) this will also stop squeeking but it needs to be reapplied every few months.
    Any type of petroleum based lubricant will first attact dirt and cause more squeeking then wash out and leave behind dirt.
    Elizabeth City, NC
    I agree with tbplus10. You put just about anything petroleum down there and its like a dust and dirt magnet. They do make these really thin teflon sheets that you can put between each leaf. Depends on how bad you want to pull your leafs apart.
  1. leaf spring fix
    By hvychev77 in forum Lifted & Offroad Suspension
    Last Post: 07-11-2010, 11:02 PM
  2. Add a leaf?
    By dshewy14 in forum General Chevy & GM Tech Questions
    Last Post: 07-11-2010, 09:32 AM
  3. Leaf springs......help
    By Spicy99Tahoe in forum Lifted & Offroad Suspension
    Last Post: 05-27-2010, 08:11 AM
  4. odd rear leaf?
    By kdr358 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-20-2009, 08:34 PM
  5. add a leaf
    By kingofthehill in forum Lifted & Offroad Suspension
    Last Post: 05-22-2008, 12:09 PM
