    Default reverse light circuit
    hey all. i have a 2009 crew cab ls 1500 and was wanting to put some lights on the hitch along with a back up camera. mu question is do you think i would be putting to much of a load on the reverse circuit if i tap into the reverse lights to get power for the camera and 2 55w driving lights. or should i just put the lights on there own circuit. thanks for the help in advance!
    2009 silverado crewcab ls - VA
    When I wired my backup camera in, I found that my trailer wiring pigtail had a reverse light circuit built into it. Since none of my trailers have back up lights, I just wired into that.
    Quote Originally Posted by agerangere5 View Post
    Hi,
    I would check what the rating on the fuse is for backup trailer lights. I agree with previous post - backup camera getting power from the trailer harness is the best way to go. 110W worth of lights I am not sure about... 10 Amp... So if its on a 15 or more amp fuse, you should be OK...
    thanks guys. i decided to just wire the lights to their own switch. this way i can turn them on when i want to. thanks for the advice though
    Best way to do it. The NBSU switch is really only designed for the stock bulbs. If you want extra lights to come on when you go to reverse, use a relay and the hot lead in the trailer harness.
  1. Reverse Light replacement
    By lakechevy1 in forum Lighting Discussion
    Last: 06-13-2010, 04:35 PM
  2. Wiring harness charge circuit available??
    By dgajr in forum General Chevy & GM Tech Questions
    Last: 08-30-2009, 09:58 AM
  3. Darn Circuit City
    By Crakums_GT in forum Audio, Video & Gadget Tech
    Last: 03-19-2009, 06:40 AM
  4. P0405 EGR Sensor A Circuit Low
    By dmbaero in forum GM Powertrain
    Last: 12-07-2008, 05:18 AM
  5. a rant of my own (circuit city)
    By 89suburban350 in forum The Coffee Shop ~ Chit Chat
    Last: 08-22-2007, 03:55 PM
