Results 1 to 2 of 2
    Arrow 95 tahoe 4 wheel drive not working
    here's the deal. I just bought this truck and the 4 wheel drive doesn't work. I'm pretty sure I have narrowed it down to the shift actuator. here is whats going on. the drive shaft turns when the truck is shifted into 4 wheel drive. I have 12 volts at my shift actuator and my grounds are good. I took the actuator out and installed a used junk yard actuator and it still doesn't work. I can put the truck in 4 wheel drive and watch the actuator and it does not move. how ever if I apply 12 volts and a ground manually from the battery it does come out slowly. Does anyone know any for sure way to test these actuators? Any ideas? Thanks.........more info... today I bought a new actuator and the 4 wheel drive is still not working. Does anyone know where I can get the 4 wheel drive schematics for this truck?
    I see this thread is a couple months old, but if you haven't been able to fix the problem you may want to check the vacuum switch on top of the tranfer case.
    I know on my S10's its located on the driverside and has three vacuum lines running into the top of it. Once you remove it, you can see it has a ball valve located on the bottom. Sometimes this valve gets rusted and will stick and nolonger perform properly.
    I hope this helps. Good luck.
    99 GMC Sonoma HighRider M5
    99 Pontiac Firebird Formula M6
    97 S10 Blazer 4x4 A4
  1. converting 2 whel drive to 4 wheel drive
    By jdaugherty3 in forum GM Powertrain
    Last Post: 11-24-2013, 07:15 AM
  2. 4 Wheel Drive not working
    By 178kchevy in forum General Chevy & GM Tech Questions
    Last Post: 01-31-2010, 12:28 PM
  3. Four Wheel Drive ( when to use it )
    By Alaskan in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-08-2010, 11:30 AM
  4. will not go into 4 wheel drive
    By emmanuel in forum GM Powertrain
    Last Post: 11-29-2009, 08:27 PM
  5. Steering wheel controls not working
    By zorg in forum General Chevy & GM Tech Questions
    Last Post: 04-23-2008, 03:26 PM
