Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Quote Originally Posted by stephan View Post
    Hey Jason, spacers work well on carbed engines, but the general consensus is that they don't work on FI engines.
    Yeah that's what I was pretty much getting at. For tuned port, There might be slight measurable differences if you had the tools to actually tell, but $ to gain is no contest. Really if you care that much about your plenum volume, then you should have the right intake and not need a spacer. As 1LOW4x4 said, Money best spent elsewhere.
    Now I still think there is some benefit on TBI, just not as much or as necessary as with a carb, but still some value nonetheless
  2. #22
    stephan's Avatar
    Far West, Oregon USA,
    Quote Originally Posted by dualdj1 View Post
    LOL Jason, My post was to the original poster who is Jason. I wouldn't presume to tell you about that, cuz you know more about that stuff than most of us here.
    3" susp. lift kit "shadetree"
  3. #23
    Just a clarification :D
  4. #24
    Newbie bradn4's Avatar
    Jul 2012
    Nashville, Tennessee
    the throttle space uses the same principle in adding height to your intake manifold in an old truck. It gives you more rev, fuel economy, and power. I had a 1972 Chevy Super Cheyenne 350 with a high rise intake, and it made the tach go to 6k rpm, when it originally was set for 5k from the factory. It does work. I am about to put one on my 04 Chevy Silverado, with a cold air intake.
  5. #25
    Sr. Engineer
    Jun 2009
    San Diego, CA
    Quote Originally Posted by bradn4 View Post
    Two totally different engines, the TBS won't do anything for your 04.
    Black Bear Performance- Custom Tuning Solutions
    Authorized EFILive and MAGNACHARGER seller
  6. #26
    i have not tried a spacer nor bought one. but i saw a video that a guy had a 90 or 91 k5 blazer. that he had installed the tbi spacer on and reported that he did feel a pickup in power. though he did do a vortec head swap. wish somebody did a dyno run...
  7. #27
    Jul 2012
    Default spacers do work
    Quote Originally Posted by JennaBear View Post
    The only difference is that the throttle body is on its side, instead of on top. the engine it self has not changed since it was invented. the only different engine is a rotary engine, that is another story. the problem with people is that they will believe anything, until you put a vehicle on a dyno. they think a throttle body will do nothing to their vehicle. the only real problem with these new engines is that fuel has to be forced sideways instead of using more gravity with a top mounted throttle body. throttle body spacers do work... you have to look at the science behind them. I am super mechanically inclined, and i know for a fact that you add space between your intake and the engine, you will get more power, by creating a vortex and "sucking" more fuel and air into the engine... if you put a high rise intake, it does the same thing.
  1. Throttle Body Spacer
    By Jarrett in forum Performance & Fuel
    Last: 01-05-2010, 11:22 PM
  2. Throttle Body Spacer
    By chevycamarado in forum Performance & Fuel
    Last: 10-03-2009, 09:04 PM
  3. Throttle Body Spacer
    By Schwindle in forum Chevy Truck Accessories
    Last: 09-06-2009, 09:06 PM
  4. Throttle Body Spacer
    By SGT_Z85 in forum GM Powertrain
    Last: 06-29-2009, 02:00 PM
  5. throttle body spacer
    By tgibson12 in forum Performance & Fuel
    Last: 10-19-2007, 03:16 AM
